| Operating System | Windows - Windows 10 Pro on x86_64 |
| Product | AMPService ‘Proteus’ v2.8.0.4 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
I know this is vague but I don’t know my next steps in troubleshooting this. Here are the error logs:
Loaded InstanceManagerPlugin by CubeCoders Limited
ADSModule requests dependency SystemUserManagerPlugin...
Loaded SystemUserManagerPlugin by CubeCoders Limited
Loaded steamcmdplugin by CubeCoders Limited
ADS startup complete in 35ms
Updating remote source CubeCoders/AMPTemplates:main
Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
error: bad signature 0x00000000
fatal: index file corrupt
git stash failed on repo CubeCoders/AMPTemplates:main with error code 128
Using keypair with fingerprint G6so/Pfmt+WbXhYOaX1LxiPGlp+QC0qnIPTd9Nd8Er0=
Failed to update CubeCoders/AMPTemplates:main
Failed to locate Open.Nat via late assembly resolver (tried D:\AMPDatastore\Instances\ADS01\Plugins\System.Reflection\Open.Nat.dll)
Missing plugin/assembly: Open.Nat
Tried: D:\AMPDatastore\Instances\ADS01\Plugins\Open.Nat\Open.Nat.dll, D:\AMPDatastore\Instances\ADS01\Plugins\Open.Nat\Open.Nat.dll, D:\AMPDatastore\Instances\ADS01\Open.Nat.dll
Failed to locate AWSSDK.S3 via late assembly resolver (tried D:\AMPDatastore\Instances\ADS01\Plugins\System.Reflection\AWSSDK.S3.dll)
Missing plugin/assembly: AWSSDK.S3
Tried: D:\AMPDatastore\Instances\ADS01\Plugins\AWSSDK.S3\AWSSDK.S3.dll, D:\AMPDatastore\Instances\ADS01\Plugins\AWSSDK.S3\AWSSDK.S3.dll, D:\AMPDatastore\Instances\ADS01\AWSSDK.S3.dll
Checking for AMP updates...
AMP is up to date.
Instance ProjectZomboid01 requires update before startup...
Refreshing instance config for ProjectZomboid01 with source CubeCoders-AMPTemplates-main
Non-managed instances exist, autoconfigure cannot guarantee that the configuration is valid!
Template refresh after upgrade failed for ProjectZomboid01: AMP configuration failed with return code 69632
Waiting for AMP instance to start...
AMP instance ProjectZomboid01 is now running.
Instance ProjectZomboid01 has stopped
ADS logged stopped instance ProjectZomboid01 - exit code 69632 (BAD_CONFIGURATION)
- Restarted modem, router, server pc, and amp
- Tried making new instance
- Updated amp
- I don’t know if this is something that should be fixed in AMP or if it’s a network issue. I just don’t know where to start.
- Any help is greatly appreciated.
