| Operating System | Windows - Windows 10 Home on x86_64 |
| Product | AMPService ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
Checking the log, I get the error LIM - failure to make api call to MinecraftServer01: An error occurred while sending the request. It will look like it has started, but when I try to manage the instance it says “This instance is not running” before shutting off quite quickly after.
- I turn on the server
- I hit “manage instance” although the server crashes even if I dont do that
- The instance crashes with the error below.
