| Operating System | Linux - Debian GNU/Linux 11 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.4 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
Hi, I tried to fetch the Greenlan Dev templates last night and my panel is stuck in fetching resources mode for almost 10 hours. I tried to check console for information however it doesn’t show anything. Can you please assist?
- From your AMP homepage (not in an Instance), goto Configuration > Instance Deployment
- Under the Configuration Respositories section, press add.
- Type
Greelan/AMPTemplates:devand hit okay. - Press Fetch Latest, let AMP work (stuck in fetch mode)
