Startup Issue with Application Deployment - "Failed to login to remote instance. Token Rejected"
Product AMP ‘Callisto’ v2.5.0.12 (Mainline)
Virtualization QEMU_KVM
“Failed to login to remote instance. Token Rejected” when trying to launch a Minecraft Java Edition server instance.
    1. Create Instance
    1. Select “Minecraft Java Edition” Application
    1. Start Instance
This issue is under investigation
If you do a force refresh of the panel and login, is it slow to load? Do you see text instead of icons for some time? And when you hit manage, does it sit there blinking for a while before giving the error?
