OS Name/Version:
Microsoft Windows 11 Pro
OS Version: 10.0.26100 N/A Build 26100
Product Name/Version: 2.6.5 - 20260114.3
I am not able to run Docker based instances, I have tried creating Terraria (vanilla) and Tshock servers and I get the following error:
Unable to complete task
This task could not be completed: Starting Instance - Starting T Server Docker (TServerDocker01)... - State: 3.
Startup failure: Docker returned error code 125. Please check the AMP Logs for further info.
I went through this guide to setup Docker containers
Here is the related Deployment log
:admin07:48:48
debian: Pulling from cubecoders/ampbase
Digest: sha256:9ecc9d4ec7194eec6097aa364683b778c6a1dc76516a5af2c57f1ac64dbb90dc
Status: Image is up to date for cubecoders/ampbase:debian
docker.io/cubecoders/ampbase:debian
ee08ed7590666122e855b416d950424c5cbe38a45e41262782b4b06a20605093
07:48:49
Slow method invocation: StartInstance took 2738ms to complete.
Slow response: ADSModule.StartInstance took 2739ms to complete.
07:49:03
07:49:04
docker: Error response from daemon: Conflict. The container name "/AMP_TServerDocker01" is already in use by container "ee08ed7590666122e855b416d950424c5cbe38a45e41262782b4b06a20605093". You have to remove (or rename) that container to be able to reuse that name.
Run 'docker run --help' for more information
On Docker desktop, I can see that the container has been created:
And here is the relative Docker desktop log:
[Info] AMPStart for Docker
[Info] Setting up amp user and group...
useradd: warning: the home directory /home/amp already exists.
useradd: Not copying any file from skel directory into it.
[Info] Starting AMP...
[11:48:52] [Program Info/1] : Starting AMP version 2.6.5.0 (Phobos), built 14/01/2026 16:43
[11:48:52] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[11:48:52] [Program Info/1] : Running in a Docker environment.
[11:48:52] [Program Info/1] : OS: Linux / x86_64
[11:48:52] [Program Info/1] : CPU: AMD Ryzen 7 5825U (8C/16T)
[11:48:52] [Program Info/1] : RAM: 15690MB
[11:48:52] [Program Info/1] : AMP Instance ID: 4267ccf8-bc4f-4a6c-b43b-585bcc13d650
[11:48:54] [Core Info/1] : Loaded GenericModule version 2.6.5 by CubeCoders Limited
[11:48:54] [Core Info/1] : Metrics publishing is enabled at udp://host.docker.internal:12820.
[11:48:55] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[11:48:55] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[11:48:55] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[11:48:55] [Loader Info/1] : Loaded WebhookPlugin by CubeCoders Limited
[11:48:56] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[11:48:56] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[11:48:57] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[11:48:57] [Loader Info/1] : GenericModule requests dependency steamcmdplugin...
[11:48:57] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[11:48:57] [Loader Info/1] : GenericModule requests dependency RCONPlugin...
[11:48:57] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[11:48:57] [Core Info/1] : Licence Present: AMP Advanced Edition - Lifetime Licence
[11:48:58] [Loader Notice/1] : Using keypair with fingerprint pNzPgM81YbYDbOljXWmLVAMW/CKDAC+gR6Q1ZH/lW/8=
[11:48:58] [Loader Info/1] : SFTP Server started on 0.0.0.0:2225
[11:48:59] [Core Info/1] : Webserver started on http://0.0.0.0:8082
[11:48:59] [System Info/7] : Checking for AMP updates...
[11:48:59] [System Info/11] : AMP is up to date.
So it appears that Docker containers and instances are created, but I am not able to start them on AMP.
- Followed these instructions to enable Docker container deployment.
- Navigate to AMP instance manager and create a new Terraria Server or Tshock Terraria server
- Instance is created, but fails to run it→ this is were I get the
Unable to complete taskerror
- Restarted PC
- Updated Docker & AMP
- Reviewed guide
- Deleted Docker container and recreated another instance.
