Startup Issue with Application Deployment - crahs
got this message:
Reconnecting
Your connection to the AMP backend was lost. AMP will attempt to reestablish a connection. If you chose to have your password remembered, you will be logged in automatically without interruption.
main/WARN
1:33:16
Mod file /home/amp/.ampdata/instances/BETATESTER01/Minecraft/libraries/net/minecraftforge/fmlcore/1.20-46.0.14/fmlcore-1.20-46.0.14.jar is missing mods.toml file
Mod file /home/amp/.ampdata/instances/BETATESTER01/Minecraft/libraries/net/minecraftforge/javafmllanguage/1.20-46.0.14/javafmllanguage-1.20-46.0.14.jar is missing mods.toml file
Mod file /home/amp/.ampdata/instances/BETATESTER01/Minecraft/libraries/net/minecraftforge/lowcodelanguage/1.20-46.0.14/lowcodelanguage-1.20-46.0.14.jar is missing mods.toml file
Mod file /home/amp/.ampdata/instances/BETATESTER01/Minecraft/libraries/net/minecraftforge/mclanguage/1.20-46.0.14/mclanguage-1.20-46.0.14.jar is missing mods.toml file
The first one is normal if there’s too much CPU/Disk/Network being used on a low-powered system, just need to wait for it to reconnect.
And for those few lines, those are warnings, not errors.
Please provide the actual logs/latest.log using something like https://mclo.gs/ if you’re running into server crashes.
