| Operating System | Linux - Ubuntu 22.04.5 on x86_64 |
| Product | AMP ‘Phobos’ v2.6.0.2 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
2 instances will not show CPU stats on main instance screen, and show application waiting. the instances actually ARE started if you “manage” then. the main page never updates though.
one other instance i have works fine, it shows “started” and shows the cpu/mem stats.
the working one is the newest instance i created. other two not working are much older.
all three instances are minecraft.
- Load amp and start my instance
- open amp web interface
- use eyes and look at screen. notice only one of my three instances show stats.
- also notice the two not showing stats show “waiting”
- clicking manage on the two not working instances show me that they are actually started and showing stats on on the manage screen just no the main instance list
