Startup Issue with Application Deployment - Counter-strike: Source Instances Do Not Work
Virtualization QEMU_KVM
This was working up until a few days ago. I did do an AMP update so if it’s possible to roll that back and see if things go back to working, I’d appreciate that.
Otherwise, I would appreciate someone taking a look at why Counter-strike: Source instances no longer work on my server. It is one of the primary reasons I rent this server space.
  • Create a new instance on this server
  • select Counter-strike: Source as the application/game to install
  • Wait for the instance setup to finish
  • try to launch the instance’s application - it fails every time
Are you on the latest patch? Also you created the ticket from ADS rather than the specific game so I’m missing the required information.
