Startup Issue with Application Deployment - Can't start instance
Virtualization QEMU_KVM
This task could not be completed: Starting Instance - Starting Minecraft (Minecraft01)… - State: 3.
Startup failure: Error code 125. Please check the AMP Logs for further info.
  • Start the instance
  • Get an error
  • Call support
Loaded ADSModule version 2.7 by CubeCoders Limited
Loaded FileManagerPlugin by CubeCoders Limited
Loaded EmailSenderPlugin by CubeCoders Limited
Loaded WebRequestPlugin by CubeCoders Limited
Loaded WebhookPlugin by CubeCoders Limited
Loaded CommonCorePlugin by CubeCoders Limited
Loaded StorePlugin by StorePlugin
ADSModule requests dependency InstanceManagerPlugin...
Loaded InstanceManagerPlugin by CubeCoders Limited
ADSModule requests dependency SystemUserManagerPlugin...
Loaded SystemUserManagerPlugin by CubeCoders Limited
Licence Present: AMP Enterprise Edition - Lifetime Licence
Loaded steamcmdplugin by CubeCoders Limited
ADS startup complete in 68ms
Updating remote source CubeCoders/AMPTemplates:main
Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
No stash entries found.
Using keypair with fingerprint 4+++Aso/CxA7WIeSg+Qsbb5NkDsYF1IY+wJZyUypdZM=
Webserver started on http://127.0.0.1:8080
Checking for AMP updates...
Startup mode is StartApplication.
AMP is up to date.
java: Pulling from cubecoders/ampbase
Digest: sha256:ae78c646e46307e91eda96e561700808a82067c85c44fe614420c6c4137497e2
Status: Image is up to date for cubecoders/ampbase:java
docker.io/cubecoders/ampbase:java
docker: Error response from daemon: Conflict. The container name "/AMP_Minecraft01" is already in use by container "110b09e96729fe45e70bd223c6233503bd742ce5f3bb2026f04a8495b627cfd2". You have to remove (or rename) that container to be able to reuse that name.
Run 'docker run --help' for more information
