| Product | AMP ‘Deimos’ v2.7.2.8 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
Running command line: "/usr/bin/podman ps --format {{.Names}}" from ""
Running command line: "/usr/bin/podman pull cubecoders/ampbase:debian" from ""
Trying to pull docker.io/cubecoders/ampbase:debian...
Getting image source signatures
Copying blob sha256:608a5f2f7d7e8b748dfca747c6838668425a022d25ce5fb75ddfb8158b2b47a4
Copying blob sha256:5b4d6ff92fc4e14e911b7753c954fac965d48c40fe1075758d284148ccace970
Copying blob sha256:36ecda2ccb1fd713da25aca5749377a5503fc87e4bf3f37dd5381b8fa41a530c
Copying blob sha256:e280df9484a8e7e98819a9813ac96eae32321763e326fd508d355ddf504828f3
Copying config sha256:9a7de8efda2551288ea318ca27648d20cb5989e0e5de0484ff93513b6c8675c7
Writing manifest to image destination
Running command line: "/usr/bin/id -u" from ""
Running command line: "/usr/bin/id -g" from ""
Running command line: "/usr/bin/podman ps -a --filter name=^AMP_ts601$ --format {{.Names}}" from ""
Running command line: "/usr/bin/podman run --rm -d --name AMP_ts601 -e AMPUSERID=1001 -e AMPGROUPID=1001 -e AMPHOSTPLATFORM=Linux -e AMP_INSTANCE_ID=9222858e-6ad4-42f4-83c7-69190a38ec29 -e AMP_MOUNTPOINTS="" --replace --uidmap +1001:@1001:1 --gidmap +1001:@1001:1 -e AMP_CONTAINER=2 -v "/home/amp/.ampdata/instances/ts601":/AMP:z -v "/home/amp/.ampdata/instances/ts601/.virtualhome":/home/amp:z --net=host -e AMP_CONTAINER_HOST_NETWORK=1 cubecoders/ampbase:debian +Core.Webserver.Port \"8081\" +Core.Webserver.IPBinding \"127.0.0.1\" +Core.AMP.InstanceID \"9222858e-6ad4-42f4-83c7-69190a38ec29\" +Core.Security.MetricsHMAKKey \"b75c5d86-5ba3-4b62-8df4-63d7c09f1d6e\"" from ""
3e890d36af8008c00a0e0fc5ab36df94227ee59a57668364aed6b00279c0ec96
Task Starting Instance (Starting ts6 (ts601)...) ended: Finished
- fesh new install of debian
- installed amp
- created ts and aska instance
wenn i start the instance it goes into waiting and then just stops
