Startup Issue with Application Deployment - Cant Manage Instance
When I try to manage an instance i create i get an error message
  • Local
  • Start Instance
  • Go to Manage Instance
What’s the output of ampinstmgr status in the command prompt?
Here is what i get.
Under Configuration → New Instance Defaults - make sure that the auth server URL is set to http://localhost:8081/ - then create a new instance.
Ok so i fixed the problem. I right clicked on the datastore and selected Repair Datastore. After that nothing showed up but then I restarted my PC and all my instances now show up. Then i found the AMPConfig.conf for each instance and changed the localhost to 8081 and now they all work.
