Dom1
1
| Field |
Value |
| Operating System |
Linux - Debian GNU/Linux 11 on x86_64 |
| Product |
AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization |
QEMU_KVM |
| Application |
Application Deployment |
| Module |
ADSModule |
| Running in Container |
No |
| Current State |
Indeterminate |
Create Instance Failed: The specified IP address could not be found on this machine. Please check that…
- Try to create instance
- Selecting game (Minecraft)
- Attempt to create
- Error shows up
Check your IP settings under Configuration > Networking
They should look like this:
Dom1
3
Hi BroOtti,
Thanks for the prompt response. It’s giving me this error now:
Failed to login to remote instance. null
Unknown Reason
Mike
4
Are you using the main admin user - or one you created after the fact?
Dom1
5
Yep, the admin user. We migrated the server then all the issues started happening
Mike
6
Can you elaborate as to what the server migration entailed?
Dom1
7
Just migrated the server from USA to India servers to lower ping
Mike
8
Spell out for me what the migration process looks like? Because that could mean any number of things.
Dom1
9
Went to the Hostinger panel → under “VPS information” → Location → Switched from USA to India
Mike
10
You should contact Hostinger in this case, they may need to reactivate everything.
Dom1
11
Ah okay, thank you! I’ll get in touch with them then
system
Closed
12
