Startup Issue with Application Deployment - Can only run 5 minecraft servers at once
Virtualization QEMU_KVM
I have an advanced licence so surely im not hitting an instance limit?
  • start 6 minecraft servers (one is bungee)
  • try to start a 7th and it will not start the instance.
  • error log shows a ilimit of 128?
Did you ever upgrade from Standard to Advanced? If so you might want to double check that you’ve reactivated the instances with your new Advanced licence.
