System Information Controller
| Operating System | Linux - Ubuntu 22.04.3 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.8 (Mainline) |
| Virtualization | VMware |
| Module | ADSModule |
| Running in Container | No |
System Information Target
| Operating System | Windows - Windows 11 Pro on x86_64 |
| Current State | Ready |
Hello, I am getting this error when starting AMP in windows as a target. Controller is Linux based. Doesnt seem to cause visible issues however instance takes around 8 minutes to start up. This also happens to every instance that is on the windows target aswell, games take 8 minutes to start up
[23:38:07] [AMPService Info] : Starting AMPService version 2.4.6.8 (Decadeus), built 26/11/2023 20:19
[23:38:07] [AMPService Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[23:38:07] [AMPService Info] : Running in a VMware environment.
[23:38:07] [GSMyAdmin Info] : Purging old audit logs (this may take a moment)…
[23:38:07] [AMPService Info] : OS: Windows / x86_64
[23:38:07] [AMPService Info] : CPU: Intel(R) Xeon(R) CPU E7-4850 v4 @ 2.10GHz (12C/12T)
[23:38:07] [AMPService Info] : RAM: 65534MB
[23:38:07] [AMPService Info] : AMP Instance ID: 02424f62-b032-4e60-a4ed-7a792b6acfeb
[23:42:21] [GSMyAdmin Warning] : Certificate chain is invalid!
[23:42:21] [GSMyAdmin Warning] : Bad status for CN=Sectigo Public Code Signing CA R36, O=Sectigo Limited, C=GB (8CF91A600B8A4A8EDC5A92D3A59FE255A9C4C558) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:42:21] [GSMyAdmin Warning] : Bad status for CN=Sectigo Public Code Signing Root R46, O=Sectigo Limited, C=GB (0BC5E76773D2E44FC9903D4DFEFE451553BBEC4A) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:42:21] [GSMyAdmin Warning] : Bad status for CN=AAA Certificate Services, O=Comodo CA Limited, L=Salford, S=Greater Manchester, C=GB (329B78A5C9EBC2043242DE90CE1B7C6B1BA6C692) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:46:34] [GSMyAdmin Warning] : Certificate chain is invalid!
[23:46:34] [GSMyAdmin Warning] : Bad status for CN=Sectigo Public Code Signing CA R36, O=Sectigo Limited, C=GB (8CF91A600B8A4A8EDC5A92D3A59FE255A9C4C558) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:46:34] [GSMyAdmin Warning] : Bad status for CN=Sectigo Public Code Signing Root R46, O=Sectigo Limited, C=GB (0BC5E76773D2E44FC9903D4DFEFE451553BBEC4A) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:46:34] [GSMyAdmin Warning] : Bad status for CN=AAA Certificate Services, O=Comodo CA Limited, L=Salford, S=Greater Manchester, C=GB (329B78A5C9EBC2043242DE90CE1B7C6B1BA6C692) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:46:34] [GSMyAdmin Warning] : Assembly Newtonsoft.Json was loaded for Core via fallback handler, check plugin dependencies.
[23:50:50] [GSMyAdmin Warning] : Certificate chain is invalid!
[23:50:50] [GSMyAdmin Warning] : Bad status for CN=Sectigo Public Code Signing CA R36, O=Sectigo Limited, C=GB (8CF91A600B8A4A8EDC5A92D3A59FE255A9C4C558) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:50:50] [GSMyAdmin Warning] : Bad status for CN=Sectigo Public Code Signing Root R46, O=Sectigo Limited, C=GB (0BC5E76773D2E44FC9903D4DFEFE451553BBEC4A) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:50:50] [GSMyAdmin Warning] : Bad status for CN=AAA Certificate Services, O=Comodo CA Limited, L=Salford, S=Greater Manchester, C=GB (329B78A5C9EBC2043242DE90CE1B7C6B1BA6C692) : RevocationStatusUnknown - The revocation function was unable to check revocation for the certificate.
[23:50:50] [GSMyAdmin Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[23:50:50] [Core Info] : Metrics publishing is enabled at udp://private:12820.
- Start AMP Instance
- Wait For Instance To Start
- View Logs
