| Operating System | Windows - Windows Server 2019 on x86_64 |
| Product | AMPService ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
I created a few instances all with different settings and made a new datastore.
After I restart my pc amp loads normally but my instances do not. the panel is empty.
In AMP’s file manager, I can see the instances that I’ve made. So it seems on boot AMP isnt loading them?
Just wondering if I need to how to uninstall and reinstall AMP to maybe fix it?
- Install AMP using installer for Windows
- create instances
- rebooted pc
