| Operating System | Linux - Ubuntu 22.04.2 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
Hi. I installed FiveM and if i try to startup i get this error:
ADS logged stopped instance ForceV01 - exit code -1 (CATASTROPHIC_FAILURE)
[23:43:09] [Logger Info] : Starting AMP version 2.4.6.6 (Decadeus), built 05/10/2023 11:56
[23:43:09] [Logger Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[23:43:09] [Logger Info] : Running in a Docker environment.
[23:43:09] [Logger Info] : OS: Linux / x86_64
[23:43:09] [Logger Info] : CPU: Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz (4C/8T)
[23:43:09] [Logger Info] : RAM: 32053MB
[23:43:09] [Logger Info] : AMP Instance ID: 7e3042a6-f955-498b-8063-91f9b0c5ab99
[23:43:10] [Logger Info] : Loaded FiveMModule version 1.0.0.0 by CubeCoders Limited
[23:43:10] [Logger Info] : Metrics publishing is enabled at udp://81.169.171.120:12820.
[23:43:10] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[23:43:10] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[23:43:10] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[23:43:10] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[23:43:10] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[23:43:10] [Logger Info] : Licence Present: AMP Professional Edition
[23:43:10] [Logger Notice] : Using keypair with fingerprint ymGFEN+9aJi8WdXsR3dc7+vqTIno3Fo49oU8EgZx9c4=
[23:43:10] [Logger Info] : SFTP Server started on 81.169.171.120:2232
[23:43:10] [Webserver Info] : Websockets are enabled.
[23:43:10] [Logger Info] : Webserver started on http://81.169.171.120:8089
[23:43:10] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[23:43:10] [Core Info] : Checking for AMP updates…
[23:43:10] [Logger Info] : Startup mode is StartApplication.
[23:43:10] [ErrorReporter Error] : Unhandled Exception: Please report this to the AMP developers.
[23:43:10] [ErrorReporter Error] : [Error] — Begin Exception Data —
[Error] OS: Linux (x86_64/Docker)
[Error] Module: FiveMModule, Version: AMP 2.4.6.6
[Error] Instance ID: 7e3042a6-f955-498b-8063-91f9b0c5ab99
[Error] NullReferenceException
[Error] [0] (NullReferenceException) : Object reference not set to an instance of an object
[Error] at FiveMModule.FiveMApp.WriteConfig ()
at FiveMModule.FiveMApp.Start ()
at GSMyAdmin.Core.StartUpdateApp (GSMyAdmin.Config config, ModuleShared.IApplicationWrapper App)
[Error] — End Exception Data —
[Warning] Last error was raised less than 60 minutes ago, error report will not be submitted.
[23:43:10] [ErrorReporter Info] : ####################################
[23:43:10] [ErrorReporter Info] : # Self Diagnostics #
[23:43:10] [ErrorReporter Info] : This exception was caused by a null reference or null argument. This is usually caused by a bug in AMP, or a plugin.
[23:43:10] [Logger Info] : The exception message was: Object reference not set to an instance of an object
its a linux server.
AMP is up to date
- Installed and updated Fivem
- Started FiveM Instance
- Get an error, i send the log in the ticket
