Startup Issue with Abiotic Factor - Abiotic Factor (Hotfix 0.9.1.11753) - AMP Server won't start
Operating System Windows - Windows 11 Home on x86_64
Application Abiotic Factor
Current State Starting
  1. AMP Release “Callisto” V. 2.5.1.8 Build 17/09/2024 12:32
  • All Server Instances uses the same AMP Release
  1. Abiotic Factor Instance was updated to the newest Patch from 20.09.2024
    Means: Hotfix 0.9.1.11753 Changes
  2. The following Error Messages occure within the AMP “Console” Logs:
a) [626]LogOnlineSession: Warning: STEAM: Cannot create session ‘GameSession’: session already exists.
b)
[ 30]LogSockets: Warning: SteamSockets: Cannot get information on an invalid socket handle, returning null
[2024.09.20-12.18.30:994][ 30]LogNet: Error: LoadMap: failed to Listen(/Game/Maps/Facility?Listen?bPassthrough)
  • Update Abiotic Factor to the newest Hotfix 0.9.1.11753 from 20.09.2024
  • Update to the latest AMP Version 2.5.1.8 Build 17/09/2024 12:32
  • Start the Abitic AMP Dedicated Server
  • Read the Detail Description within this Ticket
You will need to create a new instance
After I created a new Abiotic Factor Instance and copied the World & Character Save from the old instance, everything works.
But the interesting part is why the old instance still not starts?
But thank you very much Greelan.
Yours sincerly
Juwi
The AF devs changed the server networking and so the template needed to change, but can’t be done on existing instances
