Startup issue on all instances v2.4.6.8
Product Name/Version: v2.4.6.8
Problem Description: All my servers (maiinly ark) since last update (last night) are stuck in a starting loop , yet the servers are actually up, ive tried everything and there seems to be issue where amp thinks its still starting, and it stops console or other schedule items i have from working, worked fine until this update yesterday?.
Are you talking about AMP itself or the application within AMP?
amp since the last update (last night) if i look at the instances they just say starting constantly but they are up and working, something broke it in that update i think.
Have you checked the logs to see what they say?
nothing just this and as said it ts started but amp sees it as starting since last update;
[17:31:34] [AMPService Info] : Starting AMPService version 2.4.6.8 (Decadeus), built 23/11/2023 12:29
[17:31:34] [AMPService Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[17:31:34] [GSMyAdmin Info] : Purging old audit logs (this may take a moment)…
[17:31:34] [AMPService Info] : OS: Windows / x86_64
[17:31:34] [AMPService Info] : CPU: AMD Ryzen 5 3600XT 6-Core Processor (6C/12T)
[17:31:34] [AMPService Info] : RAM: 32663MB
[17:31:34] [AMPService Info] : AMP Instance ID: 5c6174d3-baf8-4c5f-adbe-81a5cd7b1b2c
[17:31:34] [GSMyAdmin Warning] : Assembly Newtonsoft.Json was loaded for Core via fallback handler, check plugin dependencies.
[17:31:34] [GSMyAdmin Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[17:31:34] [GSMyAdmin Info] : Loaded FileManagerPlugin by CubeCoders Limited
[17:31:34] [GSMyAdmin Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[17:31:34] [GSMyAdmin Info] : Loaded WebRequestPlugin by CubeCoders Limited
[17:31:34] [GSMyAdmin Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[17:31:34] [GSMyAdmin Info] : Loaded CommonCorePlugin by CubeCoders Limited
[17:31:34] [GSMyAdmin Info] : ADSModule requests dependency InstanceManagerPlugin…
[17:31:35] [GSMyAdmin Info] : Loaded InstanceManagerPlugin by CubeCoders Limited
[17:31:35] [GSMyAdmin Info] : ADSModule requests dependency SystemUserManagerPlugin…
[17:31:35] [GSMyAdmin Info] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[17:31:35] [GSMyAdmin Info] : Loaded steamcmdplugin by CubeCoders Limited
[17:31:35] [Core Info] : Metrics server started OK on port 12820
[17:31:35] [ADS Info] : ADS startup complete in 141ms
[17:31:35] [ADS Info] : Updating remote source CubeCoders/AMPTemplates
[17:31:35] [FileManager Notice] : Using keypair with fingerprint SEpdCiLjyLlBvUZ0x3K9bSEPLEv46zEpN/DQBTcvj/0=
[17:31:35] [FileManager Info] : SFTP Server started on 0.0.0.0:2223
[17:31:35] [GSMyAdmin Info] : Websockets are enabled.
[17:31:35] [GSMyAdmin Info] : Webserver started on http://0.0.0.0:8080
[17:31:35] [Webserver Info] : RouterTimer@10Hz with 2 jobs started
[17:31:35] [GSMyAdmin Info] : Checking for AMP updates…
[17:31:35] [GSMyAdmin Info] : Startup mode is StartApplication.
[17:31:35] [GSMyAdmin Info] : AMP is up to date.
And what does ampinstmgr ports say for the ADS01 instance?
D:\AMPDatastore\Instances\ADS01>ampinstmgr ports
[Info] AMP Instance Manager v2.4.6.6 built 05/10/2023 11:57
Please enter value for Instance Name
ADS01
[Info] Port usage for ADS01 (ADS)
[Info] Instance is currently running.
[Info] LISTENING 8080 TCP (Core.Webserver.Port)
That implies that AMP itself is running just fine? Can you show me in more detail what’s going on?
Also the log you shared is from the ADS instance, not the actual game server instances.
get this for the actual gamerserver, reason it says ports in use as it actually started it but amp doesnt recognise this
heres the gameserver logs
[22:23:17] [Program Info] : Starting AMP version 2.4.6.8 (Decadeus), built 23/11/2023 12:29
[22:23:17] [Program Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[22:23:17] [Core Info] : Purging old audit logs (this may take a moment)…
[22:23:17] [Program Info] : OS: Windows / x86_64
[22:23:17] [Program Info] : CPU: Intel(R) Xeon(R) CPU E3-1245 v5 @ 3.50GHz (4C/8T)
[22:23:17] [Program Info] : RAM: 32687MB
[22:23:17] [Program Info] : AMP Instance ID: a2e93052-8f33-438b-85b8-2e1de5fbd311
[22:23:17] [Loader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[22:23:17] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[22:23:18] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[22:23:18] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[22:23:18] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[22:23:18] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[22:23:18] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[22:23:18] [Loader Info] : GenericModule requests dependency steamcmdplugin…
[22:23:18] [Loader Info] : Loaded steamcmdplugin by CubeCoders Limited
[22:23:18] [Loader Info] : GenericModule requests dependency RCONPlugin…
[22:23:18] [Loader Info] : Loaded RCONPlugin by CubeCoders Limited
[22:23:18] [Scheduler Warning] : Schedule trigger bbee41a4-8237-4047-8728-622039848576 has a mismatched ID!
[22:23:18] [Scheduler Warning] : Schedule trigger c7d1bdfb-5b56-4af1-8afd-6c278963e9eb has a mismatched ID!
[22:23:18] [Scheduler Warning] : Schedule trigger 6352631b-4d3d-4e2a-a52f-453ec79f4f63 has a mismatched ID!
[22:23:18] [Core Info] : Licence Present: AMP Standard Edition
[22:23:18] [FileManager Error] : Unable to start SFTP server.
[22:23:18] [Core Error] : InvalidOperationException
[22:23:18] [Core Error] : [0] (InvalidOperationException) : The specified socket is already in use.
[22:23:18] [Core Error] : at kdbmv.ssrok.thtoq(EndPoint p0, Boolean p1)
at kdbmv.ssrok..ctor(EndPoint ep, String hostname, xqkcu runner)
at Rebex.Net.Servers.Core.Server.Bind(IPEndPoint endPoint, ServerModule module)
at FileManagerPlugin.PluginMain.PostInit()
[22:23:18] [Core Error] : SocketException
[22:23:18] [Core Error] : [1] (SocketException) : Only one usage of each socket address (protocol/network address/port) is normally permitted
[22:23:18] [Core Error] : at Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at Net.Sockets.Socket.Bind(EndPoint localEP)
[22:23:18] [Webserver Info] : Websockets are enabled.
[22:23:19] [Webserver Info] : Webserver started on http://0.0.0.0:8081
[22:23:19] [Webserver Info] : RouterTimer@10Hz with 2 jobs started
[22:23:19] [ErrorReporter Error] : Socket exception - Trivial error / user error. Will not be submitted.
[22:23:19] [ErrorReporter Error] : [Error] — Begin Exception Data —
[Error] OS: Windows (x86_64/None)
[Error] Module: GenericModule, Version: AMP 2.4.6.8
[Error] Instance ID: a2e93052-8f33-438b-85b8-2e1de5fbd311
[Error] SocketException
[Error] [0] (SocketException) : Only one usage of each socket address (protocol/network address/port) is normally permitted
[Error] at Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at Net.Sockets.TcpListener.Start(Int32 backlog)
at m.Http.HttpBackend.ConnectionLoop()
[Error] — End Exception Data —
[22:23:19] [ErrorReporter Info] : ####################################
[22:23:19] [ErrorReporter Info] : # Self Diagnostics #
[22:23:19] [ErrorReporter Info] : The IP and Port combination requested by the socket is already in use by another application. Either end the other application or re-bind this AMP instance to a different IP/port.
ok repaired amp etc and upgraded instances again ark se ok now and teamspeak is too, but ark sa is still in startup loop status but server is started
