Problem Description: the server cant seem to be found when looking for the game,
managing the server seems to work fine, but after clicking load game, or by trying to leave the screen and ging to join game the following lines show up in the console:
Step 2 fill in the correct IP and set the password to said server in the game so you can set a server password, the server also needs to be set up with a session save this way
Step 3wait for nothing to happen to go out of the screen after setting up your game save and password or leave after doing just that and try to join the game via the join game join game option for dedicated servers.
tried compatibility mode admin mode,.
tried port forwarding with both the firewall and the router.
tried using another port. tried using a vpn.
tried restarting the server only to have the steps repeat themselves again because that just seems to also reset game save.
tried opening the game in admin mode without compatibility mode. tried editing the server bat file with the line : -MULTIHOME=(I’m not going to post my IPaddress but you get the idea).
I tried these options so far, but I’m not certain if I missed something, but will let you know and edit this post if possible if I remember or am reminded of things I tried.
this is my first time trying to ask for help here, so if I forgot something or gotten anything wrong, please let me know so i do not make the same mistake next time I come across some problems.
I am having the same issue, I am using the internal IP (192.168.1.21:7788) in the “Manage Server” option. Seems to connect fine but get the same “… DedicatedServerSettingsComp does not exist” message when clicking “Start Game”.
is there a way to know if my router supports that? or is this just needing to wait for the dev’s to fix the issue I’m having and I just need to remain patient for the time being?
I think I also found another issue that might indicate why it is not finding the server. I had to do some digging, and maybe? it seems to spit these errors out it yellow, I am not at all familiar with Linux but I did find these errors amongst some other lines today:
[2026.01.10-08.27.20:743][ 0]LogStreaming: Warning: LoadPackage: SkipPackage: /Game/Chimera/Maps/ProceduralWorldGeneration/DedicatedServerStart/BiomesWorldInfo (0xE0264269E8DFE692) - The package to load does not exist on disk or in the loader
[2026.01.10-08.27.20:746][ 0]LogCrHints: Display: Subsystem InitializeCombinedData
[2026.01.10-08.27.20:754][ 0]LogMassReplication: UMassReplicationSubsystem: Trying to RegisterBubbleInfoClass() twice with the same BubbleInfoClass, Only one BubbleInfoClass will be registered for this type
[2026.01.10-08.27.20:754][ 0]LogLoad: Game class is 'GM_ChimeraDefault_C'
[2026.01.10-08.27.20:755][ 0]LogCrReplicationGraph: Display: Replication graph is enabled for IpNetDriver_2147481882 in world /Game/Chimera/Maps/DedicatedServerStart.DedicatedServerStart.
[2026.01.10-08.27.20:756][ 0]LogNetCore: DDoS detection status: detection enabled: 0 analytics enabled: 0
[2026.01.10-08.27.20:756][ 0]LogNet: InitBase GameNetDriver (NetDriverDefinition GameNetDriver) using replication model CrReplicationGraph
[2026.01.10-08.27.20:758][ 0]LogInit: WinSock: Socket queue. Rx: 131072 (config 131072) Tx: 131072 (config 131072)
[2026.01.10-08.27.20:758][ 0]LogNet: Created socket for bind address: 0.0.0.0:7777
[2026.01.10-08.27.20:758][ 0]PacketHandlerLog: Loaded PacketHandler component: Engine.EngineHandlerComponentFactory (StatelessConnectHandlerComponent)
[2026.01.10-08.27.20:758][ 0]LogNet: Name:GameNetDriver Def:GameNetDriver IpNetDriver_2147481882 IpNetDriver listening on port 7777
[2026.01.10-08.27.20:760][ 0]LogWorld: Bringing World /Game/Chimera/Maps/DedicatedServerStart.DedicatedServerStart up for play (max tick rate 30) at 2026.01.10-08.27.20
[2026.01.10-08.27.20:760][ 0]LogOnline: Warning: EOS: Incorrect auth parameters (Type=)
[2026.01.10-08.27.20:760][ 0]LogOnline: Warning: EOS: Unable to Login() user (0) due to missing auth parameters
[2026.01.10-08.27.20:760][ 0]LogGameSession: Warning: Autologin attempt failed, unable to register server!
[2026.01.10-08.27.20:760][ 0]LogCommonUser: Player login Completed - System:EOS, UserIdx:0, Successful:0, NewStatus:NotLoggedIn, NewId:, ErrorIfAny:Missing auth parameters
09:27:21
[2026.01.10-08.27.21:337][ 0]LogWorld: Bringing up level for play took: 0.578999
[2026.01.10-08.27.21:338][ 0]LogNavigation: Warning: NavData RegistrationFailed_AgentNotValid, NavData instance contains navmesh that doesn't support any of expected agent types.
then a whole bunch of white text which i really did not bother to add to one whole thing as the first one already a had a lot of that in it. and it should mean it works as indented until one more:
[2026.01.10-08.27.29:600][164]LogNavigation: Warning: NavData RegistrationFailed_AgentNotValid, NavData instance contains navmesh that doesn't support any of expected agent types.
I did do some reading on some websites also saying the not being able to find the server could also be not having all the certificates, but i don’t know if that is really the issue or not. and considering you already said it required NET hairpin support. which I did not find on my router, reverse proxy it does, not sure if that’s the same as loopback. as I said I’m pretty new to the whole Server hosting thing.
just thought id put it out there in case someone else has a similar issue but has the hairpin/loopback support. or if it turns out I did have the support because i just am not familiar with the terminology.
and before anyone asks or wonders why i am posting this now, I did update the server files today which is why I went and checked again since the devs of the game did in fact update their own game today. even saying they did fix some issues with dedicated servers. so i wanted to see, and its still a nope with the joining.
