OS Name/Version: Ubuntu 20.04.4 LTS
Product Name/Version: AMP v2.3.4.4
Problem Description: I need a guide on how to create a Team Fortress 2 Classic (mod) server using the SRCDS module to fetch Source SDK 2013 Multiplayer Base Dedicated Server.
It is recommended to create a Generic configuration. Here are some helpful guides/links:
It seems like I can’t do the configurator because it requires both a SRCDS download and then a zip from their website for TF2C? How would I do Multiple Update Stages/Sources manually?
You can find an example here:
Generic would be better for this actually than trying to use the existing SRCDS module - since Generic supports multiple update stages.
