Srcds Module broken since 1 month
OS Name/Version: Debian GNU/Linux 12 (bookworm) x86_64 - Kernel: 6.1.0-26-amd64
Product Name/Version: AMP Advanced Edition 2.6.0.6
Problem Description: Since AMP 2.6.0.0 the srcds module is defective and no longer works with any CSS, TF2, GMOD and L4D2 server. The server can no longer be started.
  • all srcds Server not starting anymore
[00:00:00] [srcds Info/11] : Source RCON disconnecting…
[00:00:00] [srcds Error/11] : Source RCON failed to disconnect:
Object reference not set to an instance of an object.
[00:00:00] [RCON Error/11] : NullReferenceException
[00:00:00] [RCON Error/11] : [0] (NullReferenceException) : Object reference not set to an instance of an object.
[00:00:00] [RCON Error/11] : at RCONPlugin.SourceRconClient.Disconnect()
[00:00:00] [srcds Debug/11] : Application state changed from Starting to Stopped
[00:00:00] [System Warning/11] : Server failed to start 3/5 times…
same error with docker container and without docker container …
Thanks for help! :wink:
TF2, GMod and now L4D2 don’t use the srcds module anymore - there are generic module templates for those
Why has AMP 2.6.x.x only made work for you? Everything worked fine before and now since this update nothing works anymore …
Is there a way to change the start options for the srcds module? Instead of using srcds_run, then srcds_linux?
Maybe I can fix it myself. Because I don’t want to recreate the instances again.
There is not. It is a closed source module.
Can Mike maybe fix the module for SRCDS? I mean, it’s just a problem for RCON, why the instance fails to start, according to the log.
The RCON not connecting is a symptom of the server failing to start, not the cause
Why is it written like this in the log?
