OS Name/Version: Ubuntu 22.04
Product Name/Version: AMP Release "Decadeus"v2.4.6.6
Fresh copy of Space Engineers is failing to install.
This is built in docker and is giving me the following error
Note# i’m not adding in the fresh download logs as you know what they look like, it’s fresh…
Update state (0x101) committing, progress: 96.80 (6200828232 / 6406140094)
dlmopen steamservice.so failed: steamservice.so: cannot open shared object file: No such file or directory
Success! App '298740' fully installed.
quit
[00:53:40] [steamcmdplugin Info] : SteamCMD Update successful
[01:01:12] [Logger Info] : Merging config file ./space-engineers-generic/298740/./servers/SpaceEngineers-Dedicated.cfg (XML format)
[01:01:12] [Logger Warning] : No XML document node could be found for Stream
[01:01:12] [Logger Warning] : No XML document node could be found for CustomWorld
[01:01:12] [Logger Warning] : No XML document node could be found for CustomScenario
[01:01:12] [Logger Warning] : Tried to merge config file ./space-engineers-generic/298740/./servers/Saves/World/Sandbox_config.sbc but the file does not exist.
[01:11:40] [Logger Activity] : Authentication attempt for user wardude202 from 127.0.0.1
[01:11:40] [Core Activity] : Authentication success
[01:13:11] [Logger Activity] : Authentication attempt for user wardude202 from 127.0.0.1
[01:13:11] [Core Activity] : Authentication success
[01:13:13] [API:wardude202 Activity] : Starting the application.
[01:13:13] [Logger:wardude202 Info] : Merging config file ./space-engineers-generic/298740/./servers/SpaceEngineers-Dedicated.cfg (XML format)
[01:13:13] [Logger:wardude202 Warning] : No XML document node could be found for Stream
[01:13:13] [Logger:wardude202 Warning] : No XML document node could be found for CustomWorld
[01:13:13] [Logger:wardude202 Warning] : No XML document node could be found for CustomScenario
[01:13:13] [Logger:wardude202 Warning] : Tried to merge config file ./space-engineers-generic/298740/./servers/Saves/World/Sandbox_config.sbc but the file does not exist.
[01:13:15] [Logger:wardude202 Warning] : The application stopped unexpectedly. Exit code 53
[01:13:18] [Logger:wardude202 Info] : Merging config file ./space-engineers-generic/298740/./servers/SpaceEngineers-Dedicated.cfg (XML format)
[01:13:18] [Logger:wardude202 Warning] : No XML document node could be found for Stream
[01:13:18] [Logger:wardude202 Warning] : No XML document node could be found for CustomWorld
[01:13:18] [Logger:wardude202 Warning] : No XML document node could be found for CustomScenario
[01:13:18] [Logger:wardude202 Warning] : Tried to merge config file ./space-engineers-generic/298740/./servers/Saves/World/Sandbox_config.sbc but the file does not exist.
[01:13:19] [Logger:wardude202 Warning] : The application stopped unexpectedly. Exit code 53
[01:13:19] [Generic:wardude202 Warning] : Failed to update child process.
[01:13:22] [Logger:wardude202 Info] : Merging config file ./space-engineers-generic/298740/./servers/SpaceEngineers-Dedicated.cfg (XML format)
[01:13:22] [Logger:wardude202 Warning] : No XML document node could be found for Stream
[01:13:22] [Logger:wardude202 Warning] : No XML document node could be found for CustomWorld
[01:13:22] [Logger:wardude202 Warning] : No XML document node could be found for CustomScenario
[01:13:22] [Logger:wardude202 Warning] : Tried to merge config file ./space-engineers-generic/298740/./servers/Saves/World/Sandbox_config.sbc but the file does not exist.
[01:13:23] [Core:wardude202 Error] : NullReferenceException
[01:13:23] [Logger:wardude202 Error] : [0] (NullReferenceException) : Object reference not set to an instance of an object
[01:13:23] [Core:wardude202 Error] : at GenericModule.GenericApp.SendSignal (GenericModule.GenericModuleConfig+ExitMethod method)
[01:13:23] [Generic:wardude202 Warning] : Failed to update child process.
- Create a new instance with the docker being turned on, set after creation
Full Update and Startup - Wait for it to do the update … when it tries to startup it gives me the error.
Tried with both cubecoders/ampbase:wine8 AND cubecoders/ampbase:wine base images.
Tried like 4-5 different new instances with different base images and steps to reproduce.
Tried to update the base image, same issue.
Checked other threads, none have said how the issue was solved.
