Sons of the forest server does not work
OS Name/Version: Windows Server 2025 24H2 26100.7462
Product Name/Version: AMP Release “Phobos” v2.6.4.2, built 10/12/2025 02:35
I created a Sons of the Forest dedicated server via AMP, but I am unable to connect to it. I have tested other game servers on the same setup, and they work correctly, which indicates that the issue is specific to this server.
During troubleshooting, I investigated with guidance from ChatGPT and discovered that the steam_appid.txt file appears to list the client AppID instead of the server AppID. This seems to be preventing connections, and even direct attempts to connect to the server fail.
Additionally, the server logs display repeated Steam-related assertion failures:
src\clientdll\steamengine.cpp (3529) : Assertion Failed: Attempt to call interface with invalid hSteamUser
src\common\interfacemap.cpp (874) : Assertion Failed: IPC call to IClientHTTP::ReleaseHTTPRequest returned failure code 12
These errors reference AppID 1326470 and occur during headless server initialization. The server runs in headless/dedicated mode without the full Steam client GUI. Despite the errors, the server starts, but the logs are filled with these assertion messages.
Goal / Request from AMP support:
  • Confirm whether these Steam assertion errors are expected in headless mode.
  • Advise on the correct configuration or fix for the steam_appid.txt file so that the server runs with the proper AppID.
  • Ensure the server is fully compatible with Steam functionality to allow client connections.
  • I have reinstalled the server multiple times and the issue keeps happening wiht sons of the forst specificly.
Actions taken to resolve so far: Tried manually changing the AppId but when starting the server, the config get changed back and restarts.
The server only lists on LAN regardless of the settings in AMP, the network test option fails becuase the AppId for Sons of the forest in AMP is incorrect. Kindly confirm or assist with installation.
I have the same error and have tried quite a few things to try and get it to work
So I had to add the dedicated server’s exe to the firewall exception now it is listing normally, haven’t tested it in game but I can now add the server to my server list in steam using my public ip
