[SOLVED] Icarus instance setup fails with Exit code -1073741515
Fix for this issue found here:
OS Name/Version: Windows Server 2022 (21H2)
Product Name/Version: AMP v2.4.6.6, built 05/10/2023 11:56
Problem Description: Icarus instance setup fails with Exit code -1073741515
  • Install AMP and run initial setup
  • Login to control panel
  • Create instance of Icarus
  • Error code after steam update
  • Removed Icarus instance and reinstalled
  • Completely removed AMP, service, all AMPDatastore folders/files
  • Made sure no trace of AMP was on computer
  • Installed AMP again completely clean
  • Accessed control panel and created instance of Icarus
  • Fails with Exit code -1073741515
I have followed the above steps several times over and cannot get Icarus to install
I can successfully install and launch other game servers such as Valheim.
Icarus is the only instance i cannot get to work.
The most recent log is below. The log has never varied and reports always the same.
[03:50:04] [Program Info]         : Starting AMP version 2.4.6.6 (Decadeus), built 05/10/2023 11:56
[03:50:04] [Program Info]         : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[03:50:04] [Core Warning]         : Current time zone is set to AUS Eastern Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[03:50:04] [Program Info]         : OS: Windows / x86_64
[03:50:04] [Program Info]         : CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz (6C/6T)
[03:50:04] [Program Info]         : RAM: 32631MB
[03:50:04] [Program Info]         : AMP Instance ID: ace22625-1b17-4cdc-b5ad-713bb6d42bd2
[03:50:04] [Loader Info]          : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[03:50:04] [Core Info]            : Metrics publishing is enabled at udp://localhost:12820.
[03:50:04] [Loader Info]          : Loaded FileManagerPlugin by CubeCoders Limited
[03:50:04] [Loader Info]          : Loaded EmailSenderPlugin by CubeCoders Limited
[03:50:04] [Loader Info]          : Loaded WebRequestPlugin by CubeCoders Limited
[03:50:04] [Loader Info]          : Loaded LocalFileBackupPlugin by CubeCoders Limited
[03:50:04] [Loader Info]          : Loaded CommonCorePlugin by CubeCoders Limited
[03:50:04] [Loader Info]          : GenericModule requests dependency steamcmdplugin...
[03:50:04] [Loader Info]          : Loaded steamcmdplugin by CubeCoders Limited
[03:50:04] [Loader Info]          : GenericModule requests dependency RCONPlugin...
[03:50:04] [Loader Info]          : Loaded RCONPlugin by CubeCoders Limited
[03:50:04] [Core Warning]         : Unable to update setting node GenericModule.App.Ports.$GamePort - the target type of (List<PortRequirement>) is not supported.
[03:50:04] [Core Warning]         : Unable to update setting node GenericModule.App.Ports.$QueryPort - the target type of (List<PortRequirement>) is not supported.
[03:50:04] [Core Info]            : Licence Present: AMP Standard Edition
[03:50:04] [FileManager Notice]   : No SSH keypair available for embedded server, generating new keypair...
[03:50:04] [FileManager Notice]   : Generated new keypair with fingerprint rnSaauBYo+Q90yXxo4zx4OYX8+A4Bbdp2sWTEJW0ju8=
[03:50:04] [FileManager Notice]   : Using keypair with fingerprint rnSaauBYo+Q90yXxo4zx4OYX8+A4Bbdp2sWTEJW0ju8=
[03:50:04] [FileManager Info]     : SFTP Server started on 0.0.0.0:2224
[03:50:04] [Webserver Info]       : Websockets are enabled.
[03:50:05] [Webserver Info]       : Webserver started on http://127.0.0.1:8081
[03:50:05] [Webserver Info]       : RouterTimer@10Hz with 2 jobs started
[03:50:05] [Core Info]            : Checking for AMP updates...
[03:50:05] [Core Info]            : Startup mode is UpdateAndStart.
CPID: 8024
[03:50:06] [Core Info]            : AMP is up to date.
Redirecting stderr to 'C:\AMPDatastore\Instances\Icarus01\icarus\logs\stderr.txt'
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
[  0%] Checking for available update...
[----] Downloading update (0 of 68,709 KB)...
[  0%] Downloading update (0 of 68,709 KB)...
[  0%] Downloading update (6,245 of 68,709 KB)...
[  9%] Downloading update (15,111 of 68,709 KB)...
[ 21%] Downloading update (22,908 of 68,709 KB)...
[ 33%] Downloading update (28,811 of 68,709 KB)...
[ 41%] Downloading update (33,093 of 68,709 KB)...
[ 48%] Downloading update (37,633 of 68,709 KB)...
[ 54%] Downloading update (42,501 of 68,709 KB)...
[ 61%] Downloading update (47,406 of 68,709 KB)...
[ 68%] Downloading update (51,982 of 68,709 KB)...
[ 75%] Downloading update (56,714 of 68,709 KB)...
[ 82%] Downloading update (61,312 of 68,709 KB)...
[ 89%] Downloading update (65,951 of 68,709 KB)...
[ 95%] Downloading update (68,709 of 68,709 KB)...
[100%] Download Complete.
[----] Applying update...
[----] Extracting package...
[----] Installing update...
[----] Cleaning up...
[----] Update complete, launching...
Logging directory: 'C:\AMPDatastore\Instances\Icarus01\icarus/logs'
[  0%] Checking for available updates...
[  0%] Downloading update...
[----] Downloading update (0 of 45,120 KB)...
[  0%] Downloading update (5,196 of 45,120 KB)...
[ 11%] Downloading update (12,614 of 45,120 KB)...
[ 27%] Downloading update (22,011 of 45,120 KB)...
[ 48%] Downloading update (29,769 of 45,120 KB)...
[ 65%] Downloading update (38,350 of 45,120 KB)...
[ 84%] Downloading update (45,120 of 45,120 KB)...
[100%] Download complete.
[----] Update complete, launching Steamcmd...
Steam Console Client (c) Valve Corporation - version 1696019544
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir 2089300
Waiting for user info...OK
app_update 2089300 -beta public validate
[03:50:28] [Core Activity]        : Authentication attempt for user admin from 127.0.0.1
[03:50:30] [Core Activity]        : Authentication success
[03:50:30] [Core Warning]         : Slow method invocation: Login took 2798ms to complete.
[03:50:30] [Core Warning]         : Slow response: Core.Login took 2806ms to complete.
 Update state (0x61) downloading, progress: 0.36 (59482848 / 16752057063)
 Update state (0x61) downloading, progress: 1.34 (225113648 / 16752057063)
 Update state (0x61) downloading, progress: 2.45 (410864702 / 16752057063)
 Update state (0x61) downloading, progress: 4.79 (801726917 / 16752057063)
 Update state (0x61) downloading, progress: 5.39 (902964081 / 16752057063)
 Update state (0x61) downloading, progress: 6.87 (1151442567 / 16752057063)
 Update state (0x61) downloading, progress: 7.58 (1269293046 / 16752057063)
 Update state (0x61) downloading, progress: 8.28 (1386693574 / 16752057063)
 Update state (0x61) downloading, progress: 10.46 (1752799075 / 16752057063)
 Update state (0x61) downloading, progress: 12.96 (2171384145 / 16752057063)
 Update state (0x61) downloading, progress: 13.59 (2276019272 / 16752057063)
 Update state (0x61) downloading, progress: 15.12 (2533057732 / 16752057063)
 Update state (0x61) downloading, progress: 15.60 (2612547021 / 16752057063)
 Update state (0x61) downloading, progress: 17.04 (2854294890 / 16752057063)
 Update state (0x61) downloading, progress: 18.85 (3157262311 / 16752057063)
 Update state (0x61) downloading, progress: 19.83 (3322177423 / 16752057063)
 Update state (0x61) downloading, progress: 19.94 (3341051791 / 16752057063)
 Update state (0x61) downloading, progress: 20.86 (3493912918 / 16752057063)
 Update state (0x61) downloading, progress: 22.93 (3841320375 / 16752057063)
 Update state (0x61) downloading, progress: 24.44 (4094774032 / 16752057063)
 Update state (0x61) downloading, progress: 25.64 (4295888098 / 16752057063)
 Update state (0x61) downloading, progress: 25.96 (4349349090 / 16752057063)
 Update state (0x61) downloading, progress: 27.00 (4523681382 / 16752057063)
 Update state (0x61) downloading, progress: 28.76 (4818521988 / 16752057063)
 Update state (0x61) downloading, progress: 31.18 (5223060859 / 16752057063)
 Update state (0x61) downloading, progress: 33.12 (5547819318 / 16752057063)
 Update state (0x61) downloading, progress: 34.47 (5775127089 / 16752057063)
 Update state (0x61) downloading, progress: 36.21 (6065813640 / 16752057063)
 Update state (0x61) downloading, progress: 37.47 (6277075488 / 16752057063)
 Update state (0x61) downloading, progress: 38.44 (6439271220 / 16752057063)
 Update state (0x61) downloading, progress: 39.33 (6589265284 / 16752057063)
 Update state (0x61) downloading, progress: 40.35 (6758828065 / 16752057063)
 Update state (0x61) downloading, progress: 41.30 (6918106588 / 16752057063)
 Update state (0x61) downloading, progress: 42.38 (7100193451 / 16752057063)
 Update state (0x61) downloading, progress: 43.44 (7277342314 / 16752057063)
 Update state (0x61) downloading, progress: 44.40 (7437595207 / 16752057063)
 Update state (0x61) downloading, progress: 45.31 (7590828672 / 16752057063)
 Update state (0x61) downloading, progress: 46.27 (7750556583 / 16752057063)
 Update state (0x61) downloading, progress: 47.30 (7923505251 / 16752057063)
 Update state (0x61) downloading, progress: 48.44 (8114439749 / 16752057063)
 Update state (0x61) downloading, progress: 49.42 (8278745514 / 16752057063)
 Update state (0x61) downloading, progress: 50.27 (8421634134 / 16752057063)
 Update state (0x61) downloading, progress: 51.22 (8579824976 / 16752057063)
 Update state (0x61) downloading, progress: 52.50 (8794122305 / 16752057063)
 Update state (0x61) downloading, progress: 53.53 (8968034142 / 16752057063)
 Update state (0x61) downloading, progress: 55.75 (9339885083 / 16752057063)
 Update state (0x61) downloading, progress: 56.78 (9511085595 / 16752057063)
 Update state (0x61) downloading, progress: 57.82 (9685301688 / 16752057063)
 Update state (0x61) downloading, progress: 59.78 (10014719355 / 16752057063)
 Update state (0x61) downloading, progress: 61.16 (10246178246 / 16752057063)
 Update state (0x61) downloading, progress: 62.29 (10434874656 / 16752057063)
 Update state (0x61) downloading, progress: 63.29 (10603060134 / 16752057063)
 Update state (0x61) downloading, progress: 64.22 (10758833000 / 16752057063)
 Update state (0x61) downloading, progress: 65.50 (10972339099 / 16752057063)
 Update state (0x61) downloading, progress: 66.45 (11131476866 / 16752057063)
 Update state (0x61) downloading, progress: 67.38 (11287339161 / 16752057063)
 Update state (0x61) downloading, progress: 68.42 (11461214706 / 16752057063)
 Update state (0x61) downloading, progress: 69.48 (11638986898 / 16752057063)
 Update state (0x61) downloading, progress: 70.55 (11818779003 / 16752057063)
 Update state (0x61) downloading, progress: 71.46 (11971827269 / 16752057063)
 Update state (0x61) downloading, progress: 72.41 (12129904746 / 16752057063)
 Update state (0x61) downloading, progress: 73.46 (12306442136 / 16752057063)
 Update state (0x61) downloading, progress: 74.50 (12480596883 / 16752057063)
 Update state (0x61) downloading, progress: 75.81 (12699135583 / 16752057063)
 Update state (0x61) downloading, progress: 76.70 (12849076070 / 16752057063)
 Update state (0x61) downloading, progress: 78.02 (13069204471 / 16752057063)
 Update state (0x61) downloading, progress: 79.00 (13233382155 / 16752057063)
 Update state (0x61) downloading, progress: 81.25 (13610494155 / 16752057063)
 Update state (0x61) downloading, progress: 82.71 (13854906669 / 16752057063)
 Update state (0x61) downloading, progress: 83.65 (14013460456 / 16752057063)
 Update state (0x61) downloading, progress: 84.69 (14187417615 / 16752057063)
 Update state (0x61) downloading, progress: 85.59 (14337998814 / 16752057063)
 Update state (0x61) downloading, progress: 86.63 (14512247173 / 16752057063)
 Update state (0x61) downloading, progress: 87.56 (14667414620 / 16752057063)
 Update state (0x61) downloading, progress: 88.64 (14848821446 / 16752057063)
 Update state (0x61) downloading, progress: 89.44 (14983425388 / 16752057063)
 Update state (0x61) downloading, progress: 90.46 (15154190852 / 16752057063)
 Update state (0x61) downloading, progress: 91.49 (15327266589 / 16752057063)
 Update state (0x61) downloading, progress: 92.41 (15480843591 / 16752057063)
 Update state (0x61) downloading, progress: 93.27 (15624949033 / 16752057063)
 Update state (0x61) downloading, progress: 94.08 (15760663533 / 16752057063)
 Update state (0x61) downloading, progress: 95.22 (15950927557 / 16752057063)
 Update state (0x61) downloading, progress: 96.57 (16177891149 / 16752057063)
 Update state (0x61) downloading, progress: 97.75 (16375145897 / 16752057063)
 Update state (0x61) downloading, progress: 98.90 (16567612828 / 16752057063)
 Update state (0x81) verifying update, progress: 0.51 (85743727 / 16752057063)
 Update state (0x81) verifying update, progress: 4.72 (790065744 / 16752057063)
 Update state (0x81) verifying update, progress: 9.40 (1574329831 / 16752057063)
 Update state (0x81) verifying update, progress: 14.24 (2385812983 / 16752057063)
 Update state (0x81) verifying update, progress: 18.39 (3081458826 / 16752057063)
 Update state (0x81) verifying update, progress: 23.30 (3902414085 / 16752057063)
 Update state (0x81) verifying update, progress: 28.14 (4714549540 / 16752057063)
 Update state (0x81) verifying update, progress: 32.17 (5388890442 / 16752057063)
 Update state (0x81) verifying update, progress: 37.02 (6201033034 / 16752057063)
 Update state (0x81) verifying update, progress: 41.95 (7026884733 / 16752057063)
 Update state (0x81) verifying update, progress: 46.74 (7829443376 / 16752057063)
 Update state (0x81) verifying update, progress: 50.94 (8533992565 / 16752057063)
 Update state (0x81) verifying update, progress: 55.79 (9345660021 / 16752057063)
 Update state (0x81) verifying update, progress: 60.66 (10161058957 / 16752057063)
 Update state (0x81) verifying update, progress: 65.36 (10949466856 / 16752057063)
 Update state (0x81) verifying update, progress: 69.60 (11659786388 / 16752057063)
 Update state (0x81) verifying update, progress: 74.51 (12482596631 / 16752057063)
 Update state (0x81) verifying update, progress: 79.44 (13308220046 / 16752057063)
 Update state (0x81) verifying update, progress: 83.42 (13974168976 / 16752057063)
 Update state (0x81) verifying update, progress: 88.32 (14795088591 / 16752057063)
 Update state (0x81) verifying update, progress: 93.20 (15612584144 / 16752057063)
 Update state (0x81) verifying update, progress: 97.88 (16396246720 / 16752057063)
Success! App '2089300' fully installed.
quit
[03:54:05] [steamcmdplugin Info]  : SteamCMD Update successful
[03:54:05] [Generic Info]         : Merging config file ./icarus/2089300/Icarus/Saved/Config/WindowsServer/ServerSettings.ini (INI format) using Unicode (UTF-8) encoding.
[03:54:05] [Generic Warning]      : The application stopped unexpectedly. Exit code -1073741515
[03:54:06] [Generic Warning]      : Failed to update child process.
[03:54:06] [Generic Info]         : Merging config file ./icarus/2089300/Icarus/Saved/Config/WindowsServer/ServerSettings.ini (INI format) using Unicode (UTF-8) encoding.
[03:54:08] [Generic Info]         : Merging config file ./icarus/2089300/Icarus/Saved/Config/WindowsServer/ServerSettings.ini (INI format) using Unicode (UTF-8) encoding.
[03:54:08] [Generic Warning]      : The application stopped unexpectedly. Exit code -1073741515
[03:54:09] [Generic Warning]      : Failed to update child process.
[03:54:11] [Generic Info]         : Merging config file ./icarus/2089300/Icarus/Saved/Config/WindowsServer/ServerSettings.ini (INI format) using Unicode (UTF-8) encoding.
[03:54:11] [Generic Warning]      : The application stopped unexpectedly. Exit code -1073741515
[03:54:12] [Generic Warning]      : Failed to update child process.
[03:54:14] [Generic Info]         : Merging config file ./icarus/2089300/Icarus/Saved/Config/WindowsServer/ServerSettings.ini (INI format) using Unicode (UTF-8) encoding.
[03:54:14] [Generic Warning]      : The application stopped unexpectedly. Exit code -1073741515
[03:54:15] [Generic Warning]      : Failed to update child process.
[03:54:18] [Generic Info]         : Merging config file ./icarus/2089300/Icarus/Saved/Config/WindowsServer/ServerSettings.ini (INI format) using Unicode (UTF-8) encoding.
[03:54:18] [Generic Warning]      : The application stopped unexpectedly. Exit code -1073741515
[03:54:18] [Generic Warning]      : Application failed to start 5 times, not restarting.
[03:54:19] [Generic Warning]      : Failed to update child process.
