I am downloaded sky factory but it spawns me in a normal java world. I would like the Skyblock island or a custom island. I don’t how to do either please help me
*download the map I wanted
download the skyfactory mod
*change the server properties so that the would should generate according to the Sky Factory 4 preset
If you change the server.properties file manually, it will be overwritten by the web interface.
You need to right-click the file then import it, or update the value under Server Settings.
Be sure to delete the world folder after changing the setting, as the worldgen settings are baked into the world file and won’t change if you don’t delete the world folder.
Alternatively, you can also start a world on your client with all the settings you want, then upload that to the server.
