OS Name/Version: Windows 11 Pro
Product Name/Version: AMP Release “Phobos” v2.6.3
Minecraft v1.21.1
Fabric Loader: v0.17.2
Problem Description: When loading into the world, you immediately fall. After a minute or two, a small chunk of the map loads. Then you keep getting teleported to the same place over and over every couple of seconds until you get the error “Client disconnected with reason: Internal Exception: java.net.SocketException: Connection reset”.
- Step 1 Created Minecraft instance (fabric)
- Step 2 Configured settings for Minecraft server (ram, eula, update, version specifications)
- Step 3 Started Minecraft server
- Step 4 Wait a few minutes for startup
- Step 5 Connect to server via Minecraft & CurseForge
- Step 6 Successfully connect to server
- Step 7 Successfully proceed through loading screen
- Begin falling with no map loaded
- A very small portion of the map loads and the character spawns on it.
- Attempt to move/look around
- Character gets teleported back to spawn every couple of seconds
- After a minute or two, you get disconnected and get a “Client disconnected with reason: Internal Exception: java.net.SocketException: Connection reset” error.
- Server shows reference to something called spiffy_structures, but I don’t see where or what that could be referencing.
Tried running a barebones fabric server with the same versions. Can load into the map without falling, but then still have same the java.net.SocketException error.
