OS Name/Version:
Debian 12 (Bookworm) – fully updated
Version : 12.13
Product Name/Version:
AMP 2.6.0.10 (latest stable build)
I was previously running a standalone AMP instance on a single Linux VM to manage 4–5 game servers (Minecraft, Hytale, etc.) without any issues.
After migrating my infrastructure for better resilience and to avoid downtime during maintenance, I switched to a distributed AMP setup consisting of 3 VMs:
- 1 Controller
- 2 Target hosts
All 3 VMs are on the same network, built using the same deployment script and identical configuration parameters.
However, when managing instances on the targets from the Controller, action buttons (start/stop/restart) do not respond, and the integrated game consoles (for Minecraft, Hytale, etc.) are not functional.
Both connection modes — “via Target” and “Direct From Controller” — were tested, with the same results.
It seems I may have missed or misconfigured something in the controller/target communication, but I cannot identify what.
I’d appreciate your expertise on the proper configuration and communication flow between Controller and Targets, or hints on what could block management/console functionality in this setup.
Step 1: Deploy three Debian 12 VMs (one controller, two targets) using the same deployment script and identical AMP setup configuration.
Step 2: Register both targets into the controller using AMP’s UI.
Step 3: Attempt to control or view a game instance (e.g., Minecraft or Hytale) from the controller’s dashboard.
Step 4: Observe that action buttons and consoles are unresponsive or not loading properly.
- Verified system clocks, DNS resolution, and hostname reachability between all VMs (OK)
- Confirmed controller–target connectivity (ping OK, SSH OK)
- Network verification:
- Verified AMP ports open (8080, 8081, 8082, 8083, 2223) on all VMs:
netstat -tlnp | grep amp - Checked firewall rules:
ufw statusandiptables -L— all AMP ports allowed - Tested port connectivity between controller and targets:
nc -zv target1 8080/8081/8082/8083 - Rebound AMP services:
systemctl restart ampon all nodes
- Browser console check: F12 Developer Tools → Console/Network tabs show no errors, but WebSocket connections to targets fail/time out
- Tested both connection modes (“Via Target” and “Direct From Controller”) without success
- Restarted AMP services and instances on both controller and targets
- Checked AMP logs (
~/AMP/Logs) on all nodes for authentication/communication errors (no critical errors) - Reinstalled AMP on a fresh VM using the same procedure to rule out corruption — same behavior
- Test EnablePassthruAuth=true
- Check controller’s URL
