Setting up Sons of the Forest
OS Name/Version: Debian 12
Product Name/Version: AMP Release “Callisto” v2.5, built 15/03/2024 19:18 - Configured with Docker as requested.
Just clicked on installation of the Sons of the Forest server. Server does not start. I see no output on any logs that would indicate what the issue is causing it not to start. Only service that comes on is SFTP server. Game Port, Steam Query Port, and Blob Sync Port will flicker during start up of the server but go back to red.
Proxmox VM. CPU is set to host.
No steps to reproduce as it is the same. SotF server does not start.
Tried to reconfigure IP address information on AMP for the IP addresses to be from 0.0.0.0 to the local IP of the whole network (192.168.2.x)
Tried to reconfigure SotF server with different settings to see if this was causing it to hang up.
UPDATE:
I did disable network check and seems that it starts but I am still not able to connect to the server even though they are all green lights for the services.
