Server not waking up from playit.gg link connection
Using Debian 12 with CasaOS WebUI
Amp Pro license
Steps i tried:
-restart AMP
-restart Playit
-restart PC
-can connect with direct IP and it will wake up
Problem:
When the Server is in Sleep mode it does not wake up when you try to connect it through a Playit.gg Link but it does wake up when i connect to it with the direct IP Link. I use Playit so other people dont have my IP for the Server cause im a newbie when it comes to this stuff and other also cant connect with the direct IP
Playit.gg doesn’t work well with sleep mode due to something on their end.
Try changing the wakeup mode to Wake on ping and see if that has a different result.
