See host load or used resources
Is there a way to see the currently used resources/load of the host so I can tell if I need to offload some servers to another host? Such as CPU usage is 75% and RAM is 24gb/48gb. I know I can see on the instance what the instance is using but is there a total used somewhere?
Right now there isn’t a system-level overview of resource consumption (The way that instances handle their own resource usage calculation makes this a little challenging), but it is something due to come in a future update.
