Second ark instance can't start
Ubuntu 24.04.2:
Product Name/Version: AMP Release “Phobos” v2.6.2
I previously had an ark SE instance wich work perfectly fine. Recently I tried to create a second one for a friend of mine but it doesn’t start, no matter i choose the “minimal” version or the “classic” one, it doesn’t start, showing the following message in the webUI:
This task could not be completed: Running Update Tasks - - State: 3.
/bin/bash failed with exit code 1
and the following one in the console
bash10:50:20
SteamCMD10:50:20
[  0%] Checking for available updates...
10:50:21
UpdateUI: skip show logo
Steam Console Client (c) Valve Corporation - version 1747702063
-- type 'quit' to exit --
Loading Steam API...OK
force_install_dir "376030"
10:50:22
10:50:23
Waiting for user info...OK
app_update 376030 -beta public validate
10:50:24
IPC function call IClientAppManager::GetUpdateInfo took too long: 102 msec
IPC function call IClientAppManager::GetUpdateInfo took too long: 135 msec
Error! App '376030' state is 0x202 after update job.
quit
Unloading Steam API...OK
10:50:25
bash10:50:26
10:50:28
/bin/bash: line 1: cd: ark-se/376030/ShooterGame/Binaries: No such file or directory
ln: failed to create symbolic link 'Win64': File exists
  • Create a first Ark instance
  • Create a second one
  • Can’t start the server
None beside recreating the instance.
You don’t have enough space to install the second server.
That’s what the 202 steamcmd error code means.
You may need to look into expanding your root logical volume.
