SCP:SL and Docker Container
OS Name/Version: Linux Ubuntu 24.04.2
Product Name/Version: 2.6.1.4 - 20250410.2
Problem Description: I am having troubles with docker container, based off of other posts I believe that docker is not installed
1.Create new Instance of SCP:SL(Taking note of the docker recommendation)
  1. once SCP:SL instance has been made I go to container settings and enable it
  2. Error given
{Unable to complete task
This task could not be completed: Reconfiguring Instance - - State: 3.
Failed to configure new instance SCPSecretLaboratory01 - Couldn’t find docker - docker is required to run containerized instances. The user running AMP (amp) must also be a member of the ā€˜docker’ group.}
  1. Remove instance and go to configuration
  2. go to instance development
  3. enable "Create in Docker Containers
  4. create SCP:SL Instance
  5. Same error ā€œUnable to complete taskā€
Read as much forms and topics as I can, closest one was answered by AI for Windows 11, not Linux Ubuntu 24.04.2
I found it it was renamed Deployment Defaults. Thank you!
