Scheduled task: "If condition is met"
One of the options under schedule has the task “If condition is met” but I can’t find any documentation on how to use it. I would specifically like to know what options are available for the “ValueToCheck” field?
The values that you can check are the ones emitted by the trigger, and that show as parameters along the bottom.
