OS Name/Version: Ubuntu 20.04.4
Product Name/Version: v2.3.4
Problem Description: Time schedule task/trigger not being executed. I have backup set inside the instance to run at a specific time, but no backup have been taken. I have checked ADS01 and instance logs and not seen anything. Is there a specific log for tasks that I can check?
Upgraded the version, The webpage shows v2.4 now but cli is differnet.
root@amp10:/home/amp/.ampdata/instances/Local01/AMP_Logs# /usr/bin/ampinstmgr --version
[Info] AMP Instance Manager v2.3.4 built 16/06/2022 16:09
You update the command line tool via your systems package manager.
AMPs scheduler runs on UTC, you can check what it’s doing in terms of running the schedule by checking the logs. Make sure debug mode is enabled to see what it’s doing.
