This is a fresh ADS install on a fresh OS install with fresh Satisfactory module
OS Name/Version: Windows Server 2019
Product Name/Version: (Always use the full version number - not ‘Latest’) 2.3.2.12
Problem Description: Unable to run after fresh ADS install and Satisfactory module/template
provides syntax highlighting.
[06:31:15] [Core Info] : Running in a HyperV environment.
[06:31:15] [Core Warning] : Current time zone is set to Pacific Standard Time - Servers should ideally be UTC to avoid time-zone related issues
[06:31:15] [Core Info] : OS: Windows / x86_64
[06:31:15] [Core Info] : CPU: Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz (14C/28T)
[06:31:15] [Core Info] : AMP Instance ID: 0ebc8052-bc71-45d8-ad28-8f4d8f79cbf8
[06:31:16] [ModuleLoader Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[06:31:16] [Core Info] : Metrics publishing is enabled at udp://127.0.0.1:12820.
[06:31:16] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[06:31:16] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[06:31:16] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[06:31:16] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[06:31:16] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[06:31:16] [ModuleLoader Info] : GenericModule requests dependency steamcmdplugin...
[06:31:16] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[06:31:16] [ModuleLoader Info] : GenericModule requests dependency RCONPlugin...
[06:31:16] [ModuleLoader Info] : Loaded RCONPlugin version 1.0.0.1 by CubeCoders Limited
[06:31:16] [Core Info] : Licence Present: AMP Network Standard Edition (Licenced to Kevin Casey)
[06:31:16] [ModuleLoader Notice] : Using keypair with fingerprint Xbn4K6cnnbjdg+zU0av7xD/xElk5RMB8+5FCGg6E9E0=
[06:31:16] [FileManager Info] : SFTP Server started on 0.0.0.0:2226
[06:31:16] [WebServer Info] : Websockets are enabled.
[06:31:16] [WebServer Info] : Webserver started on http://127.0.0.1:8083
[06:31:16] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[06:31:16] [Core Info] : Checking for AMP updates...
[06:31:17] [Core Info] : AMP is up-to-date.
[06:31:17] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1
[06:31:19] [Core:Anonymous Activity] : Authentication success
[06:31:23] [System:admin Activity] : Updating the application.
CPID: 5064
Redirecting stderr to 'C:\AMPDatastore\Instances\Casual\satisfactory\logs\stderr.txt'
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
[ 0%] Checking for available update...
[----] Downloading update (0 of 63,771 KB)...
[ 0%] Downloading update (1,440 of 63,771 KB)...
[ 2%] Downloading update (3,993 of 63,771 KB)...
[ 6%] Downloading update (6,563 of 63,771 KB)...
[ 10%] Downloading update (9,483 of 63,771 KB)...
[ 14%] Downloading update (11,309 of 63,771 KB)...
[ 17%] Downloading update (14,036 of 63,771 KB)...
[ 22%] Downloading update (16,526 of 63,771 KB)...
[ 25%] Downloading update (19,166 of 63,771 KB)...
[ 30%] Downloading update (21,899 of 63,771 KB)...
[ 34%] Downloading update (24,805 of 63,771 KB)...
[ 38%] Downloading update (28,850 of 63,771 KB)...
[ 45%] Downloading update (32,521 of 63,771 KB)...
[ 50%] Downloading update (36,769 of 63,771 KB)...
[ 57%] Downloading update (40,452 of 63,771 KB)...
[ 63%] Downloading update (44,136 of 63,771 KB)...
[ 69%] Downloading update (47,819 of 63,771 KB)...
[ 74%] Downloading update (52,027 of 63,771 KB)...
[ 81%] Downloading update (56,403 of 63,771 KB)...
[ 88%] Downloading update (59,590 of 63,771 KB)...
[ 93%] Downloading update (63,771 of 63,771 KB)...
[100%] Downloading update (63,771 of 63,771 KB)...
[100%] Download Complete.
[----] Applying update...
[----] Extracting package...
[----] Installing update...
[----] Cleaning up...
[----] Update complete, launching...
[ 0%] Downloading update...
[----] Downloading update (1,952 of 42,235 KB)...
[ 4%] Downloading update (11,243 of 42,235 KB)...
[ 26%] Downloading update (19,954 of 42,235 KB)...
[ 47%] Downloading update (26,531 of 42,235 KB)...
[ 62%] Downloading update (37,283 of 42,235 KB)...
[ 88%] Downloading update (42,235 of 42,235 KB)...
[100%] Download complete.
[----] Update complete, launching Steamcmd...
Steam Console Client (c) Valve Corporation - version 1652399510
-- type 'quit' to exit --
Loading Steam API...OK
Waiting for user info...OK
Update state (0x61) downloading, progress: 0.48 (41926040 / 8823593161)
Update state (0x61) downloading, progress: 4.52 (399084296 / 8823593161)
Update state (0x61) downloading, progress: 9.54 (842094952 / 8823593161)
Update state (0x61) downloading, progress: 15.40 (1358726920 / 8823593161)
Update state (0x61) downloading, progress: 20.30 (1790785288 / 8823593161)
Update state (0x61) downloading, progress: 25.48 (2248139528 / 8823593161)
Update state (0x61) downloading, progress: 31.34 (2764934144 / 8823593161)
Update state (0x61) downloading, progress: 36.42 (3213725079 / 8823593161)
Update state (0x61) downloading, progress: 42.55 (3754169777 / 8823593161)
Update state (0x61) downloading, progress: 48.30 (4262011723 / 8823593161)
Update state (0x61) downloading, progress: 54.99 (4852109199 / 8823593161)
Update state (0x61) downloading, progress: 60.97 (5379344344 / 8823593161)
Update state (0x61) downloading, progress: 65.34 (5764903074 / 8823593161)
Update state (0x61) downloading, progress: 68.16 (6014121383 / 8823593161)
Update state (0x61) downloading, progress: 71.44 (6303428220 / 8823593161)
Update state (0x61) downloading, progress: 74.57 (6579904628 / 8823593161)
Update state (0x61) downloading, progress: 77.74 (6859687140 / 8823593161)
Update state (0x61) downloading, progress: 80.01 (7059730107 / 8823593161)
Update state (0x61) downloading, progress: 81.81 (7218177723 / 8823593161)
Update state (0x61) downloading, progress: 83.83 (7397029563 / 8823593161)
Update state (0x61) downloading, progress: 85.51 (7545474747 / 8823593161)
Update state (0x61) downloading, progress: 87.38 (7710107323 / 8823593161)
Update state (0x61) downloading, progress: 89.08 (7859662523 / 8823593161)
Update state (0x61) downloading, progress: 90.75 (8007777979 / 8823593161)
Update state (0x61) downloading, progress: 92.64 (8173844155 / 8823593161)
Update state (0x61) downloading, progress: 94.26 (8317206203 / 8823593161)
Update state (0x61) downloading, progress: 95.28 (8407280315 / 8823593161)
Update state (0x61) downloading, progress: 97.38 (8592398805 / 8823593161)
Update state (0x61) downloading, progress: 98.88 (8724609225 / 8823593161)
Update state (0x81) verifying update, progress: 1.31 (115193752 / 8823593161)
Update state (0x81) verifying update, progress: 7.37 (650232725 / 8823593161)
Update state (0x81) verifying update, progress: 13.63 (1202503843 / 8823593161)
Update state (0x81) verifying update, progress: 19.93 (1758688575 / 8823593161)
Update state (0x81) verifying update, progress: 25.97 (2291683631 / 8823593161)
Update state (0x81) verifying update, progress: 32.52 (2869532447 / 8823593161)
Update state (0x81) verifying update, progress: 38.60 (3406162573 / 8823593161)
Update state (0x81) verifying update, progress: 44.81 (3953459635 / 8823593161)
Update state (0x81) verifying update, progress: 50.72 (4475102307 / 8823593161)
Update state (0x81) verifying update, progress: 55.62 (4907885155 / 8823593161)
Update state (0x81) verifying update, progress: 62.43 (5508594920 / 8823593161)
Update state (0x81) verifying update, progress: 69.50 (6132209788 / 8823593161)
Update state (0x81) verifying update, progress: 76.34 (6735855740 / 8823593161)
Update state (0x81) verifying update, progress: 83.25 (7345467516 / 8823593161)
Update state (0x81) verifying update, progress: 89.82 (7925706874 / 8823593161)
Update state (0x81) verifying update, progress: 95.89 (8460973541 / 8823593161)
Update state (0x0) unknown, progress: 0.00 (0 / 0)
Success! App '1690800' fully installed.
[06:33:36] [System:admin Activity] : Starting the application.
[06:33:36] [System:admin Warning] : The application stopped unexpectedly. Exit code -1073741515
[06:33:36] [System:admin Warning] : Application failed to start 5 times, not restarting.
[06:38:39] [System:admin Activity] : Starting the application.
[06:38:39] [System:admin Warning] : The application stopped unexpectedly. Exit code -1073741515
[06:38:39] [System:admin Warning] : Application failed to start 5 times, not restarting.
[07:18:25] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1
[07:18:26] [Core:Anonymous Activity] : Authentication success
[07:29:18] [Core:Anonymous Activity] : Authentication attempt for user admin from 127.0.0.1
[07:29:19] [Core:Anonymous Activity] : Authentication success
- Step 1 Create new Satisfactory module
- Step 2 Update / Install game files
- Step 3 Press start
Actions taken to resolve so far: Deleted module and started new and verified install of module. All other modules are working with no issue.
