It doesnt seem to work for me I setup AWS S3 and got that working fine, and it also showed me the basics, but when I went to using cloudflares R2 which supports S3 it doesnt seem to work, any thoughts?
for more context I followed their guide:
setting <https://<ACCOUNT_ID>.r2.cloudflarestorage.com> as the Backend URL
and setup a S3 API which is the equivelent to a User on AWS for AMP access
put in the keys for access, and set region to auto, as they had stated. I also tried it empty to no avail
Also having no luck setting up R2. Did you manage to find a solution to this?
Tried it with and without:
Specific regions and appending /bucketname for the backend URL
Auth region set to auto, us-east-1, or blank
Bucket name blank (with and without appending / to the backend URL)
Force path style
Disable payload signing
Have also changed the storage class from standard to none, swapped the access and secret keys in case they were back-to-front, and created a subfolder manually within the bucket (in case it was trying to upload to a subfolder that didn’t exist and the API couldn’t create).
Wondering if there are some S3 API calls being made that R2 doesn’t support yet, but AMP makes specific mention of R2 under payload signing, so surely compatible?
