| Product | AMP ‘Callisto’ v2.5.1.4 (Mainline) |
| Virtualization | QEMU_KVM |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Ready |
While using Minio as the S3 Server, as the default options, it uses a Path based URL, while the AWS SDK uses a subdomain based URL, and after trying to manually form the URL or trying the raw IP address, I can’t save my backups to my S3 Backups, even tho the same settings and credentials work on my WinSCP instance and other apps that uses S3 and allow Path based URL.
- Create a Minio S3 Server
- Setup Backup Settings with the S3 credentails, host URL, region and other necessary data
- Try to upload a backup, it will hang and eventually fail
