OS Name/Version: Ubuntu 20.04.4
Product Name/Version: Currently running version 2.4.8 - 20240129.1
Yesterday ish I set up S3 cloud backup for 4 instances. Now I’ve already used more than 2000 requests to S3 and they are forecasting around 14500 requests, which is not within the limits of their free-tier.
How is that number so high after 1-2 days?
Backup is scheduled daily at 7 AM to run and keep 4 or 5 copies.
Is it an error that it already used 2000 requests? As it should probably only use 4 requests at 7 AM when the backup runs and then some when checking the backup is there I’d assume.
- Setup & Configure S3 backup on instances and manually test upload local backups.
- Add a trigger to schedule the backup
- Wait for the backups to run and upload to S3 automatically
None yet as I can’t seem to find anything that I can do as of right now.
(PS. I tried opening a ticket through AMP, but the “create” bottom stays greyed out. And the “Steps to reproduce” is in 8/10 times saying: “The step you entered is too short or does not appear to be valid. Please enter a longer step or one that contains more words.”
No matter how many words or accurate the steps are)
