For Rust:
Platform | Windows Server 2022 |
System Type | x86_64 |
CPU Model | AMD Ryzen 7 3700X 8-Core Processor |
CPU Layout | 1S/8C/16T |
Installed RAM | 65480 |
Virtualization | None |
Module | RustModule |
Module Application | Rust Dedicated Server |
Loaded Plugins | FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin |
Application Name | AMP |
Application Version | 2.4.6.4 |
Codename | Decadeus |
Tools Version | 2.4.6.4 |
Release Stream | Mainline |
Build Spec | Release |
Build Date | 07/09/2023 18:02 |
InstanceID | ad8f2347-37ba-42d4-8c69-123741b7d89f |
Last Executable | ./rust/258550\RustDedicated.exe |
Last Arguments | -batchmode -logfile - -nographics +rcon.password ********** +server.port 28015 +server.queryport 28016 +rcon.port 5678 +app.port 28082 +server.ip 134.255.235.103 +server.seed 6738 +server.tickrate 30 +server.hostname My Rust server |
Last Process ID | 8912 |
For Minecraft:
Module | MinecraftModule |
Module Application | Minecraft |
InstanceID | 8a1ad65d-e494-4d8c-9e8a-bbbb4732c387 |
Last Executable | C:\Program Files\Java\jdk-17\bin\java.exe |
Last Arguments | -Xmx1024M -jar minecraft_server.jar nogui |
Last Process ID | 788 |
firewall ports open, everything is green and server is running.
I tried to test different IP settings but no success, servers are not found in the browser and are only displayed as 0.0.0.0:port.
Minecraft and Rust tested same result
The servers neither appear in the server list nor can I access them directly.
all up and running.
what is the default amp ip binding and what the default aplication ip? try 0.0.0.0 nothing same with my real ip and 127.0.0.1.I tested all of them but none of them worked
