Product Name/Version: AMP Professional, AMP Release Decadeus v 2.4.3
Problem Description: Running “ampinstmgr” command in command prompt throws the following error
C:\Users\Qwenton>ampinstmgr
[Info] AMP Instance Manager v2.4.3 built 14/03/2023 23:16
Unhandled Exception: System.IO.FileNotFoundException: Could not load file or assembly 'System.Net.Http, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified. ---> System.IO.FileNotFoundException: Could not load file or assembly 'System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
--- End of inner exception stack trace ---
at InstanceManagerPlugin.LocalInstanceManager..ctor(ILogger log, IAuditLog audit, IPlatformInfo platformInfo, IRunningTasksManager tasks, IFeatureManager features, IAuthenticationProvider auth, IAMPInstanceInfo instance)
at InstanceManagerCLI.Core.<Run>d__41.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at InstanceManagerCLI.Program.<Main>()
C:\Users\Qwenton>
- run “ampinstmgr” in command prompt as normal user
restarted computer
restarted amp
tried running as administrator
stopping service and running command
restarting service and running command
