Reset to Installation Wizard
OS Name/Version: Linux
Product Name/Version: v2.4.6.10, built 06/12/2023 17:17
Is there an option, configuration setting, or command to reset the panel to the installation wizard? I am using a dockerized version and I’m trying to set it up as a controller. I also have a few other potential “targets” in my system I’d like to re-run the wizard on.
I’m a developer so I don’t mind digging into code or database entries to accomplish it.
  • I’ve gone through all of the available docs and forum topics and have not been able to find anything yet
on the main part of the panel its Configuration > New Instances Defaults and you will see a button called Re-Run Setup
That’s it, thanks so much. Don’t know how I kept missing it.
