RePOST: Unable to get instance to start
Original thread. I responded and then it went 30 days without a response and was auto closed without resolution.
OS Name/Version: Windows Server 2022
Product Name/Version: Callisto, v2.5.0.6
Problem Description: Unable to start an instance on AMP, fresh install
  1. Install AMP
  2. Setup new instance of Minecraft Java
  3. Start the instance
I’ve reinstalled windows, reinstalled amp on two different hardware systems and had the same results. I’ve also received identical results with Debian as the OS.
The system things it is starting and hangs on Waiting for data, application waiting. So, i went into the logs and took a screenshot which I’ve attached here as well. It shows the instance license then it complains saying Expected licence feature RunAmp is not present and that no license was found right after it shows the license was there.
