OS Name/Version:
(Multiple) Pop!_OS 21.10, Pop!_OS 22.04, Ubuntu 20.04.4
Product Name/Version:
AMP ‘Triton’ 2.3.3.0
RCON Passthrough is no longer working to my servers, I recently had the two Pop_OS! machines in a hybrid + target setup but switched them both to targets and added a controller. After doing this I had to create new accounts on the controller to provide auth and this setup has been working fine.
However It took me a few days to notice that RCON Passthrough was no longer working, of course this was because I never setup a new service key so a tool I use which periodically connects over RCON to run commands was attempting to use my old key for those days.
Now, even after setting up a new Service Login and restarting the two target instances and the controller even RCON Passthrough is not working at all.
Each time a service login is used by the tool in question now(I have generated a few over the last 12 hours) the amp audit log will show this error
Error handling request:[POST:/API/Core/GetActiveAMPSessions] - [ArgumentException]: System.ArgumentException: An item with the same key has already been added. Key: [SERVICE LOGIN KEY WAS HERE] at System.Collections.Generic.Dictionary`2[TKey,TValue].TryInsert (TKey key, TValue value, System.Collections.Generic.InsertionBehavior behavior) [0x000dd] in <c9084dbbb7684502983633fdd54162d8>:0 at System.Collections.Generic.Dictionary`2[TKey,TValue].Add (TKey key, TValue value) [0x00000] in <c9084dbbb7684502983633fdd54162d8>:0 at GSMyAdmin.WebServer.APIService.GetSession (System.Net.IPAddress address, System.String Session, System.String UA) [0x000a3] in <4d2291c82c2a476fb60166fd0b2e8e02>:0 at GSMyAdmin.WebServer.APIService.HandleRequest (m.Http.IHttpRequest request) [0x000f7] in <4d2291c82c2a476fb60166fd0b2e8e02>:0 at m.Http.Handlers.Handler+<>c__DisplayClass6_0.<From>b__0 (m.Http.IHttpRequest req) [0x00000] in <6ba0f115d4834d51b3526e12d15cee09>:0 at m.Http.Routing.RateLimitedEndpoint+<>c__DisplayClass4_0.<Wrap>b__0 (m.Http.IHttpRequest request) [0x00019] in <6ba0f115d4834d51b3526e12d15cee09>:0 at m.Http.Router.HandleRequest (m.Http.Backend.HttpRequest httpReq, System.DateTime requestArrivedOn) [0x000cd] in <6ba0f115d4834d51b3526e12d15cee09>:0
- Step 1 Have RCON passthrough working on a hybrid + target setup
- Step 2 Switch from hybrid to target and then add in a new controller
- Step 3 Create new service login as controller requires new accounts
- Step 4 RCON Passthrough no longer working
Not sure if this will recreate the issue or if something has gone wrong on my end.
Attempted to generate and use new service login keys multiple times (Same error from above)
Used ampinstmgr repairauth on both targets
Waited approx 8 hours since last failure before attempting again incase of rate limit
I appreciate any help with this issue as a good portion of my income hinges on this feature working.
