RCON connection refused when adding mod S+ to Ark Evolved
OS Name/Version: |OS|Windows|
|Platform|Windows 10 Pro|
|System Type|x86_64|
|CPU Model|Intel(R) Core™ i7-7700 CPU @ 3.60GHz|
|CPU Layout|1S/4C/8T|
|Installed RAM|32592|
|Virtualization|None|
|Network Mode|Standard|
|Module|GenericModule|
|Module Application|ARK: Survival Evolved|
|Loaded Plugins|FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin, AnalyticsPlugin|
|Application Name|AMP|
|Application Version|2.5.1.0|
|Codename|Callisto|
|Tools Version|2.4.6.6|
|Release Stream|Mainline|
|Build Spec|Release|
|Build Date|06/07/2024 22:13|
|InstanceID|e7948029-4ac1-4625-a115-8b3bd41b87af|
|Last Executable|C:\AMPDatastore\Instances\ARKSurvivalEvolved01\ark-se\376030\ShooterGame\Binaries\Win64\ShooterGameServer.exe|
|Last Arguments|TheIsland?listen?Port=7777?QueryPort=27016?RCONEnabled=True?RCONServerGameLogBuffer=600?RCONPort=27020?ServerAdminPassword=********** Powered ARK: Survival Evolved Server"?MultiHome=0.0.0.0?GameModIds=630601751,731604991?ServerPassword=********** -automanagedmods -crossplay -AllowFlyerSpeedLeveling -ForceAllowCaveFlyers -PreventHibernation -ActiveEvent=None -PublicIPForEpic= -culture=en -ClusterDirOverride=“C:\ArkCluster” -clusterid=1 -servergamelog|
|Last Process ID|12140|
No connection could be made because the target machine actively refused it 127.0.0.1:27020.
[19:36:50] [RCON:admin Info/3]    : Source RCON disconnecting...
[19:36:51] [RCON:admin Info/3]    : Source RCON disconnected
[19:36:55] [RCON:admin Info/3]    : Source RCON disconnecting...
[19:36:56] [RCON:admin Info/3]    : Source RCON disconnected
[19:36:58] [RCON:admin Error/3]   : Source RCON failed to connect:
  • Add “731604991” to the mod list in Ark Server Settings
  • Start the instance.
Actions taken to resolve so far: Removal of the mod will allow the instance to start and the RCON to listen.
On top is without the mod. Below it I can see it trying.
C:\Windows\system32>netstat -ano | find “:27020”
TCP 0.0.0.0:27020 0.0.0.0:0 LISTENING 12044
TCP 127.0.0.1:27020 127.0.0.1:53409 ESTABLISHED 12044
TCP 127.0.0.1:53409 127.0.0.1:27020 ESTABLISHED 14352
TCP 127.0.0.1:61390 127.0.0.1:27020 SYN_SENT 3084
Ark Server Manager works on the same ports with the mods enabled.
