OS Name/Version: Windows Server 2019 for instances/ rasp for pi
Product Name/Version: (Always use the full version number - not ‘Latest’) v2.3.4 built 16/6/22
Would like to know if u can run ADS on A raspberry pi 4 and all instances on windows server is there much lag or preformance issues?
You can do this yes. Assuming you’re just running ADS on the Pi as a controller you shouldn’t experience any performance issues.
If I already have it running as stand alone is it easy to change the pi to controller and still have instances on server?
What’s the exact set up you have currently? Changing the mode of an existing installation is fairly involved.
Atm it is standalone , would I have to buck up all instances and then uninstall amp and then install it on pinas controller and on server as target?
