Question about license keys
hello everyone, quick question. i was having alot of issues with the os i was using for amp so i ended up fully reinstalling the vm two times, well now it shows my license status as 27/15 instances, i only have two instances on the new setup, will those other instances dissapear? and can i still make more instances or should i wait for it to clear up first if it does
They will eventually update to reflect what you are using. You can add more I believe.
how long does it usually take?
