Quake live clean installation not working
I have select from drop down menu Quake Live server. I start the server but the server don’t start.
Step 1: start new istance
Step 2: select quake live from menu
Step 3: Start installation
Step 4: Check status
LINUX DEBIAN OS
Error:
Waiting for AMP instance to start…
AMP instance QuakeLiveServer101 is now running.
Instance QuakeLiveServer101 has stopped
ADS logged stopped instance QuakeLiveServer101 - exit code -1 (CATASTROPHIC_FAILURE)
183.92.151.73 has been banned from SFTP, ignoring connection attempt…
Updating remote source CubeCoders/AMPTemplates:main
Updating existing remote source GitHub - CubeCoders/AMPTemplates: For the AMP community to share Generic Module templates. · GitHub…
No stash entries found.
LastAMPExceptkon.txt
[Error] — Begin Exception Data — [Error] OS: Linux (x86_64/None) [Error] Module: GenericModule, Version: AMP 2.7.2.0 [Error] Release spec: Mainline - built by CUBECODERS/buildbot on CCL-DEV [Error] Instance ID: 8b89388c-0f87-4f42-acba-0aafecbcc2a7 [Error] KeyNotFoundException [Error] [0] (KeyNotFoundException) : The given key ‘$ApplicationIPBinding’ was not present in the dictionary. [Error] at Collections.Generic.Dictionary`2.get_Item(TKey key) at GenericModule.ModuleMain.ImportConfigFile(String finalPath, MetaConfigFile fileInfo) at GenericModule.ModuleMain.ImportMetaconfigs(String ConfigFile) at GenericModule.GenericApp.ApplicationProcess_Exited(Object sender, EventArgs e) [Error] — End Exception Data — [Warning] Last error was raised less than 60 minutes ago, error report will not be submitted.
