Jed1
August 12, 2026, 4:35pm
1
Field
Value
Operating System
Linux - Debian GNU/Linux 13 on x86_64
Product
AMP ‘Proteus’ v2.8.0.4 (Mainline)
Virtualization
Podman
Application
Project Zomboid
Module
GenericModule
Running in Container
Yes
Current State
Ready
view active users on dashboard
do you know why this wouldnt be working?
launch server
have players on the server
view dashboard, 0 active users
Mike
August 12, 2026, 9:14pm
2
If I remember rightly, Project Zomboid does not properly log player joins/leaves - so AMP can’t track who is present and the number of users.
give this a try made it myself since i had the same issue the info is there the amp team just needs to change which file they are looking at (it changes on each start so needs to be the latest file)
Temporary Self-Fix / Workaround
If you are using Project Zomboid Build 42 on AMP/Linux and AMP always shows:
Active Users: 0 / 32
even though people are connected, this workaround restores AMP’s Active Users / @UserCount tracking.
Important: This is a temporary community workaround, not an official CubeCoders fix.
It has been tested on AMP 2.8.0.4, Debian Linux, Podman and Project Zomboid Build 42.
The installer performs compatibility checks before changing AMP and creates a timestamped ba…
Jed1
August 15, 2026, 6:23pm
4
this worked for a bit, but now every time I start the instance is just thinks that 4 people are connected when there is none
