Hmm, the regex seems to match now but for some reason it still doesn’t work… (still the same behaviour)
New log
Here’s my entire GenericModule.kvp file in case it helps somehow
Meta.DisplayName=Project Zomboid
Meta.Description=Project Zomboid Dedicated Server
Meta.OS=Windows, Linux
Meta.Arch=x86_64
Meta.Author=Greelan, IceOfWraith, Dhraz
Meta.URL=https://projectzomboid.com
Meta.DisplayImageSource=steam:108600
Meta.EndpointURIFormat=steam://connect/{ip}:{GenericModule.App.ApplicationPort2}
Meta.ConfigManifest=project-zomboidconfig.json
Meta.MetaConfigManifest=project-zomboidmetaconfig.json
Meta.ConfigRoot=project-zomboid.kvp
Meta.MinAMPVersion=2.3.3.0
Meta.SpecificDockerImage=
Meta.DockerRequired=False
Meta.ContainerPolicy=Supported
Meta.Prerequsites=[]
Meta.ConfigReleaseState=NotSpecified
App.DisplayName=Project Zomboid
App.RootDir=./project-zomboid/
App.BaseDirectory=./project-zomboid/380870/
App.ExecutableWin=380870\jre64\bin\java.exe
App.ExecutableLinux=380870/ProjectZomboid64
App.WorkingDir=380870
App.LinuxCommandLineArgs=-Dzomboid.steam={{SteamInt}} -Duser.home=./ -Xmx{{MaxMemory}}m {{CustomJavaArgs}} --
App.WindowsCommandLineArgs=-Djava.awt.headless=true -Dzomboid.znetlog=1 -Dzomboid.steam={{SteamInt}} -Duser.home=./ -Xmx{{MaxMemory}}m {{JavaGCAlgo}} -XX:-CreateCoredumpOnCrash -XX:-OmitStackTraceInFastThrow -Djava.library.path=natives/;natives/win64/;. {{CustomJavaArgs}} -cp java/*;java/ zombie.network.GameServer -statistic 0 --
App.CommandLineArgs={{$PlatformArgs}} -port {{$ApplicationPort1}} -steamport1 {{$ApplicationPort2}} -steamport2 {{$ApplicationPort3}} {{CustomServerArgs}} {{$FormattedArgs}}
App.UseLinuxIOREDIR=False
App.AppSettings={"$ApplicationPort1":"16261","$ApplicationPort2":"8766","$ApplicationPort3":"8767","$RemoteAdminPort":"27015","PublicName":"ENY","Public":"true","PublicDescription":"","Password":"Riba123","adminpassword":"","RCONPassword":"1ab07447-a13f-451f-86f1-ddc2a260ef3e","ServerWelcomeMessage":"Welcome to Project Zomboid Multiplayer! <LINE> <LINE> To interact with the Chat panel: press Tab, T, or Enter. <LINE> <LINE> The Tab key will change the target stream of the message. <LINE> <LINE> Global Streams: /all <LINE> Local Streams: /say, /yell <LINE> Special Streams: /whisper, /safehouse, /faction. <LINE> <LINE> Press the Up arrow to cycle through your message history. Click the Gear icon to customize chat. <LINE> <LINE> Happy surviving!","$MaxUsers":"32","Open":"true","AutoCreateUserInWhiteList":"false","MaxMemory":"4096","JavaGCAlgo":"-XX:+UseZGC","SteamVAC":"true","SteamInt":"1","Map":"Rosewood, KY; Muldraugh, KY","Mods":"","WorkshopItems":"","DisplayUserName":"true","ShowFirstAndLastName":"false","SteamScoreboard":"true","PauseEmpty":"true","SaveWorldEveryMinutes":"15","UPnP":"false","CustomJavaArgs":"","servername":"servertest","CustomServerArgs":"","SpawnPoint":"8345,11742,0","SpawnItems":"","PVP":"false","SafetySystem":"true","ShowSafety":"true","SafetyToggleTimer":"2","SafetyCooldownTimer":"3","Faction":"true","FactionDaySurvivedToCreate":"0","GlobalChat":"true","nightlengthmodifier":"1.0","NoFire":"false","AnnounceDeath":"true","MinutesPerPage":"1.0","HoursForLootRespawn":"0","MaxItemsForLootRespawn":"4","ConstructionPreventsLootRespawn":"true","PlayerSafehouse":"true","AdminSafehouse":"false","SafehouseAllowTrepass":"true","SafehouseAllowFire":"true","SafehouseAllowLoot":"true","SafehouseAllowRespawn":"true","SafehouseDaySurvivedToClaim":"0","SafeHouseRemovalTime":"999","AllowDestructionBySledgehammer":"true","SledgehammerOnlyInSafehouse":"false","SleepAllowed":"true","SleepNeeded":"false","DiscordEnable":"false","DiscordToken":"","DiscordChannel":"","DiscordChannelID":"","EnableBeta":"false","BetaBranch":""}
App.EnvironmentVariables={"PATH":"./jre64/bin:%PATH%","LD_LIBRARY_PATH":"./linux64:./natives:./:./jre64/lib/amd64:%LD_LIBRARY_PATH%","LD_PRELOAD":"./jre64/lib/libjsig.so","PZ_CLASSPATH":"java/*;java/","SteamAppId":"108600"}
App.CommandLineParameterFormat=-{0} {1}
App.CommandLineParameterDelimiter=
App.ExitMethod=String
App.ExitTimeout=30
App.ExitString=quit
App.ExitFile=app_exit.lck
App.HasWriteableConsole=True
App.HasReadableConsole=True
App.SupportsLiveSettingsChanges=False
App.LiveSettingChangeCommandFormat=set {0} "{1}"
App.ApplicationIPBinding=0.0.0.0
App.Ports=[{"Protocol":2,"Port":19132,"Offset":0,"Range":1,"Ref":"ApplicationPort1","Name":"Application Port 1","Description":"","ChildPorts":null},{"Protocol":2,"Port":8767,"Offset":0,"Range":1,"Ref":"ApplicationPort2","Name":"Application Port 2","Description":"","ChildPorts":null},{"Protocol":2,"Port":8768,"Offset":0,"Range":1,"Ref":"ApplicationPort3","Name":"Application Port 3","Description":"","ChildPorts":null},{"Protocol":2,"Port":27018,"Offset":0,"Range":1,"Ref":"RemoteAdminPort","Name":"Application Admin Port","Description":"","ChildPorts":null}]
App.ApplicationPort1=19132
App.ApplicationPort2=8767
App.ApplicationPort3=8768
App.RemoteAdminPort=27018
App.AdminPortRef=RemoteAdminPort
App.PrimaryApplicationPortRef=ApplicationPort1
App.UniversalSleepApplicationUDPPortRef=ApplicationPort1
App.UniversalSleepSteamQueryPortRef=ApplicationPort2
App.MaxUsers=32
App.UseRandomAdminPassword=False
App.RemoteAdminPassword=Password123
App.AdminMethod=STDIO
App.AdminLoginTransform=None
App.RCONConnectDelaySeconds=5
App.RCONConnectRetrySeconds=5
App.RCONHeartbeatMinutes=0
App.RCONHeartbeatCommand=ping
App.TelnetLoginFormat={0}
App.UpdateSources=[{"UpdateStageName":"SteamCMD Download","UpdateSourcePlatform":31,"UpdateSource":4,"UpdateSourceData":"380870","UpdateSourceArgs":null,"UpdateSourceVersion":"public","UpdateSourceTarget":null,"UnzipUpdateSource":false,"OverwriteExistingFiles":false,"ForceDownloadPlatform":0,"UpdateSourceConditionSetting":"EnableBeta","UpdateSourceConditionValue":"false","DeleteAfterExtract":false},{"UpdateStageName":"SteamCMD Download","UpdateSourcePlatform":31,"UpdateSource":4,"UpdateSourceData":"380870","UpdateSourceArgs":null,"UpdateSourceVersion":"{{BetaBranch}}","UpdateSourceTarget":null,"UnzipUpdateSource":false,"OverwriteExistingFiles":false,"ForceDownloadPlatform":0,"UpdateSourceConditionSetting":"EnableBeta","UpdateSourceConditionValue":"true","DeleteAfterExtract":false},{"UpdateStageName":"Mods Directory Creation","UpdateSourcePlatform":31,"UpdateSource":1024,"UpdateSourceData":null,"UpdateSourceArgs":"./project-zomboid/380870/Zomboid/mods","UpdateSourceVersion":null,"UpdateSourceTarget":null,"UnzipUpdateSource":false,"OverwriteExistingFiles":false,"ForceDownloadPlatform":0,"UpdateSourceConditionSetting":null,"UpdateSourceConditionValue":null,"DeleteAfterExtract":false}]
App.Compatibility=None
App.SteamUpdateAnonymousLogin=True
App.SteamForceLoginPrompt=False
App.RapidStartup=False
App.MonitorChildProcess=False
App.MonitorChildProcessWaitMs=100
App.MonitorChildProcessName=
App.SupportsUniversalSleep=False
App.WakeupMode=Any
App.ApplicationReadyMode=RegexMatch
App.TemplateMatchRegex={{(\$?[\w]+)}}
Console.FilterMatchRegex=
Console.FilterMatchReplacement=
Console.ThrowawayMessageRegex=^(WARNING|ERROR): Shader.+$
Console.AppReadyRegex=^LOG\s+: Network\s+, \d+> [\d,.\s]+> \*+ SERVER STARTED \*+$
Console.UserJoinRegex=^LOG\s+: Network\s+, \d+> [\d,.\s]+> Connected new client (?<username>.+?) ID # (?<userid>.+?) and assigned DL port (?<userport>.+?)$
Console.UserLeaveRegex=^LOG\s+: (Network|General)\s+, \d+> [\d,.\s]+> (Disconnected player "(?<username>.+?)" |\d+ znet: Disconnecting client #(?<userid>.+?) SteamID=)\d+$
Console.UserChatRegex=^\[\d\d:\d\d:\d\d\] \[CHAT\] <(?<username>.+?)> (?<message>.+)$
Console.UpdateAvailableRegex=^\[\d\d:\d\d:\d\d\] \[INFO\] A new server update is available! v[\d\.]+.$
Console.MetricsRegex=
Console.SuppressLogAtStart=False
Console.ActivateLogRegex=
Console.UserActions={}
Limits.SleepMode=False
Limits.SleepOnStart=False
Limits.SleepDelayMinutes=5
Limits.DozeDelay=7
Limits.AutoRetryCount=5
Limits.SleepStartThresholdSeconds=25
