Project Zomboid server after update the triggers is not working
OS Name/Version: Debian Server
Product Name/Version: Project Zomboid server after update 41.77
Project Zomboid server after update: triggers are not working, it won’t track the active players, and there are no user triggering actions (user joined or left).
I tried to reinstall the instance and AMP, but the issue remained the same.
The server logging may have changed, so AMP’s regex is not matching.
Can you post log lines from the AMP logs showing when a user joins or leaves?
Are you using mods?
No i dont have any mods its a vanila server.
Player join:
12:18:27
LOG : Network , 1664965107090> 4,026,279,829> [05-10-22 12:18:27.089] > ZNet: SSteamSDK → SZombienet: OnP2PSessionRequest
LOG : Network , 1664965107090> 4,026,279,829> [05-10-22 12:18:27.090] > ZNet: OnP2PSessionRequest: idx=4 SteamID=76561198027971970
LOG : Network , 1664965107090> 4,026,279,829> [05-10-22 12:18:27.090] > ZNet: SZombienet → SSteamSDK: AcceptP2PSessionWithUser
12:18:31
LOG : Network , 1664965111078> 4,026,283,818> [05-10-22 12:18:31.078] > ZNet: SRakNet → SZombienet: RakNetRecvFrom
LOG : Network , 1664965111079> 4,026,283,818> [05-10-22 12:18:31.079] > ZNet: SZombienet → SZombienet: OnMsgVersionMessage
LOG : Network , 1664965111079> 4,026,283,818> [05-10-22 12:18:31.079] > ZNet: Client version=41.77.3 matches server version=41.77.3
LOG : Network , 1664965111079> 4,026,283,818> [05-10-22 12:18:31.079] > ZNet: hnote over SZombienet : ZNetServerInfoMessage
LOG : Network , 1664965111079> 4,026,283,819> [05-10-22 12:18:31.079] > ZNet: SZombienet → SSteamSDK: SendP2PPacket
LOG : Network , 1664965111208> 4,026,283,948> [05-10-22 12:18:31.208] > ZNet: SRakNet → SZombienet: OnNewConnection
LOG : Network , 1664965111209> 4,026,283,948> [05-10-22 12:18:31.209] > ZNet: OnNewConnection: 134.255.1.173:18977 incoming=1 state=Connected
LOG : Network , 1664965111210> 4,026,283,949> [05-10-22 12:18:31.210] > ZNet: [-> CZombienet: RakNetPeerInterface_getIPFromGUID
LOG : Network , 1664965111210> 4,026,283,949> [05-10-22 12:18:31.210] > ConnectionManager: [RakNet] “new-incoming-connection” connection: guid=369295192680232776 ip=null steam-id=0 access= username=“null” connection-type=“Disconnected”
LOG : Network , 1664965111599> 4,026,284,339> [05-10-22 12:18:31.599] > ZNet: SRakNet → SZombienet: OnReceive
LOG : Network , 1664965111600> 4,026,284,339> [05-10-22 12:18:31.600] > ZNet: SZombienet → SZombienet: ProcessPacket
LOG : Network , 1664965111600> 4,026,284,339> [05-10-22 12:18:31.600] > ZNet: Client has begun authentication
LOG : Network , 1664965111600> 4,026,284,339> [05-10-22 12:18:31.600] > ZNet: SZombienet → SZombienet: OnClientBeginAuth
LOG : Network , 1664965111600> 4,026,284,339> [05-10-22 12:18:31.600] > ZNet: got token from the client
LOG : Network , 1664965111600> 4,026,284,340> [05-10-22 12:18:31.600] > ZNet: SZombienet → SSteamSDK: BeginAuthSession
LOG : Network , 1664965111601> 4,026,284,340> [05-10-22 12:18:31.601] > ZNet: BeginAuthSession() ok
LOG : Network , 1664965111889> 4,026,284,628> [05-10-22 12:18:31.889] > ZNet: SSteamSDK → SZombienet: OnValidateAuthTicketResponse
LOG : Network , 1664965111890> 4,026,284,629> [05-10-22 12:18:31.890] > ZNet: OnValidateAuthTicketResponse response=OK SteamID=76561198027971970
LOG : Network , 1664965111890> 4,026,284,629> [05-10-22 12:18:31.890] > ZNet: Auth succeeded
LOG : Network , 1664965111890> 4,026,284,630> [05-10-22 12:18:31.890] > ZNet: hnote over SZombienet : mtMsgServerAuthPassed
LOG : Network , 1664965111890> 4,026,284,630> [05-10-22 12:18:31.890] > ZNet: SZombienet → SZombienet: SendServerMessage
DEBUG: Voice , 1664965111927> 4,026,284,666> VoiceManager.VoiceConnectAccept > uuid=520000568f6f748
12:18:32
LOG : Network , 1664965112185> 4,026,284,924> [05-10-22 12:18:32.185] > ConnectionManager: [receive-packet] “login” connection: guid=369295192680232776 ip=null steam-id=0 access= username=“null” connection-type=“UDPRakNet”
LOG : Network , 1664965112185> 4,026,284,925> [05-10-22 12:18:32.185] > ZNet: [-> CZombienet: RakNetPeerInterface_getIPFromGUID
LOG : Network , 1664965112186> 4,026,284,925> [05-10-22 12:18:32.186] > ZNet: [-> CZombienet: RakNetPeerInterface_GetClientSteamID
LOG : Network , 1664965112186> 4,026,284,925> [05-10-22 12:18:32.186] > ZNet: [-> CZombienet: RakNetPeerInterface_GetClientOwnerSteamID
LOG : General , 1664965112186> 4,026,284,926> User ntamas is trying to connect.
DEBUG: Multiplayer , 1664965112187> 4,026,284,927> GameServer.receiveLogin > User ntamas ping 28 ms
LOG : Network , 1664965112190> 4,026,284,929> [05-10-22 12:18:32.190] > ConnectionManager: [receive-packet] “client-connect” connection: guid=369295192680232776 ip=134.255.1.173 steam-id=76561198027971970 access=admin username=“ntamas” connection-type=“UDPRakNet”
LOG : Network , 1664965112192> 4,026,284,931> Connected new client ntamas ID # 12
DEBUG: Multiplayer , 1664965112196> 4,026,284,935> RequestDataPacket.sendConnectingDetails> ConnectionDetails 63613b
12:18:38
LOG : Network , 1664965118424> 4,026,291,163> [05-10-22 12:18:38.424] > ConnectionManager: [receive-packet] “login-queue-request” connection: guid=369295192680232776 ip=134.255.1.173 steam-id=76561198027971970 access=admin username=“ntamas” connection-type=“UDPRakNet”
DEBUG: Multiplayer , 1664965118720> 4,026,291,459> RequestDataPacket.doProcessRequest > Descriptors 4010b
DEBUG: Multiplayer , 1664965118781> 4,026,291,520> RequestDataPacket.doProcessRequest > MetaGrid 817881b
12:18:39
DEBUG: Multiplayer , 1664965119161> 4,026,291,900> RequestDataPacket.doProcessRequest > MapZone 867286b
DEBUG: Multiplayer , 1664965119590> 4,026,292,329> RequestDataPacket.doProcessRequest > PlayerZombieDescriptors 40919b
DEBUG: Multiplayer , 1664965119654> 4,026,292,394> RequestDataPacket.doProcessRequest > RadioData 12620b
12:18:40
LOG : General , 1664965120027> 4,026,292,767> NetChecksum: PacketTotalChecksum lua=true script=true
12:18:47
LOG : Network , 1664965127952> 4,026,300,691> [05-10-22 12:18:47.952] > ConnectionManager: [receive-packet] “login-queue-done” connection: guid=369295192680232776 ip=134.255.1.173 steam-id=76561198027971970 access=admin username=“ntamas” connection-type=“UDPRakNet”
12:18:50
LOG : Network , 1664965130155> 4,026,302,895> [05-10-22 12:18:50.155] > ConnectionManager: [receive-packet] “player-connect” connection: guid=369295192680232776 ip=134.255.1.173 steam-id=76561198027971970 access=admin username=“ntamas” connection-type=“UDPRakNet”
LOG : General , 1664965130156> 4,026,302,895> User:‘ntamas’ ip:134.255.1.173 is trying to connect
LOG : General , 1664965130156> 4,026,302,896> Warning, root node parent is always null.
LOG : Network , 1664965130157> 4,026,302,897> [05-10-22 12:18:50.157] > ZNet: BUpdateUserData ‘ntamas’ id=76561198027971970
LOG : Network , 1664965130158> 4,026,302,898> [05-10-22 12:18:50.158] > ConnectionManager: [fully-connected] “” connection: guid=369295192680232776 ip=134.255.1.173 steam-id=76561198027971970 access=admin username=“ntamas” connection-type=“UDPRakNet”
player left:
12:20:19
LOG : Network , 1664965219727> 4,026,392,466> [05-10-22 12:20:19.727] > ZNet: SRakNet → SZombienet: OnClosedConnection
LOG : Network , 1664965219727> 4,026,392,466> [05-10-22 12:20:19.727] > ZNet: OnClosedConnection: reason=DisconnectionNotification port=18977
LOG : Network , 1664965219727> 4,026,392,467> [05-10-22 12:20:19.727] > ZNet: Disconnecting client #3 SteamID=76561198027971970
LOG : Network , 1664965219727> 4,026,392,467> [05-10-22 12:20:19.727] > ZNet: Disconnect: DisconnectionNotification (1105) SteamID=76561198027971970
LOG : Network , 1664965219728> 4,026,392,467> [05-10-22 12:20:19.728] > ConnectionManager: [RakNet] “disconnection-notification” connection: guid=369295192680232776 ip=134.255.1.173 steam-id=76561198027971970 access=admin username=“ntamas” connection-type=“Disconnected”
LOG : Network , 1664965219742> 4,026,392,481> Disconnected player “ntamas” 76561198027971970
LOG : Network , 1664965219742> 4,026,392,481> [05-10-22 12:20:19.742] > ConnectionManager: [disconnect] “receive-disconnect” connection: guid=369295192680232776 ip=134.255.1.173 steam-id=76561198027971970 access=admin username=“ntamas” connection-type=“Disconnected”
LOG : Network , 1664965219994> 4,026,392,734> [05-10-22 12:20:19.994] > ZNet: SSteamSDK → SZombienet: OnValidateAuthTicketResponse
LOG : Network , 1664965219994> 4,026,392,734> [05-10-22 12:20:19.994] > ZNet: OnValidateAuthTicketResponse response=AuthTicketCanceled SteamID=76561198027971970
12:20:20
LOG : Network , 1664965220790> 4,026,393,529> [05-10-22 12:20:20.790] > ZNet: Finally disconnected client 76561198027971970
LOG : Network , 1664965220790> 4,026,393,530> [05-10-22 12:20:20.790] > ZNet: SZombienet → SZombienet: CloseConnection
LOG : Network , 1664965220790> 4,026,393,530> [05-10-22 12:20:20.790] > ZNet: CloseConnection: Finally disconnected (1101) SteamID=76561198027971970
LOG : Network , 1664965220790> 4,026,393,530> [05-10-22 12:20:20.790] > ZNet: SZombienet → SSteamSDK: CloseP2PSessionWithUser
LOG : Network , 1664965220792> 4,026,393,532> [05-10-22 12:20:20.792] > ZNet: SZombienet → SSteamSDK: EndAuthSession
Thanks. I see now as well the stable version has added the new udp port (default 16262) and deprecated the two steam ports
OK, because of the port change the server logging for user joins has changed.
Stop your instance, then go into the PZ instance datastore through the main AMP File Manager, and edit GenericModule.kvp. Change the Console.UserJoinRegex line to look like:
Console.UserJoinRegex=^LOG\s+: Network\s+, \d+>.*> Connected new client (?<username>.+?) ID # (?<userid>.+?)$
Now I’ve noticed something strange
randomly got triggered by the “user left” trigger even though nobody left the server.
Log:
LOG : General , 1664973241615> 4,034,414,355> shared-descriptor: added id=1018
14:35:07
LOG : General , 1664973307800> 4,034,480,540> coop player=1/4 username=“BullFather” is joining
LOG : General , 1664973307802> 4,034,480,541> coop player=1/4 username=“BullFather” is replacing dead player
14:35:08
LOG : Network , 1664973307802> 4,034,480,542> Disconnected player “BullFather” 76561198100304903
LOG : General , 1664973307803> 4,034,480,543> Player with PlayerID =‘0’ not found!
LOG : Network , 1664973308045> 4,034,480,784> DISCORD: get message on current channel
LOG : Network , 1664973308045> 4,034,480,784> DISCORD: send message = “” for Szerver-Infó)
LOG : General , 1664973308178> 4,034,480,918> command entered via server console (System.in): “servermsg “ntamas Lelépett a Szerverről””
LOG : General , 1664973308217> 4,034,480,956> Message ‘ChatMessage{chat=Server, author=‘Server’, text=‘ntamas Lelépett a Szerverről’}’ was sent to player with id ‘4’ of chat ‘5’
LOG : General , 1664973308217> 4,034,480,957> Message ‘ChatMessage{chat=Server, author=‘Server’, text=‘ntamas Lelépett a Szerverről’}’ was sent to player with id ‘8’ of chat ‘5’
